Home » Eclipse Projects » Rich Client Platform (RCP) » Description of handler definition in plugin.xml
Description of handler definition in plugin.xml [message #664025] Thu, 07 April 2011 04:34 Go to next message
hi,
is there any possibility to add at least in the plugin.xml a description to the handler definition?
I have a lot of handlers defined. If i need to find the handlers definition to change the activeWhen/enabledWhen constraints, one have to move step by step through the hole list to find the specific handler.
http://www.fotos-hochladen.net/uploads/handlerwodesctqckbxydrp.png
Any other tips for managing handlers are appreciated too Smile
regards
Johan
Re: Description of handler definition in plugin.xml [message #664253 is a reply to message #664025] Fri, 08 April 2011 01:46 Go to previous message
On 07/04/11 2:04 PM, Johan Schulz wrote:
> hi,
Since handlers are not shown to the user and read only by the
framework, adding description to a handler isn't a good idea.
You should use the normal XML comments in the plugin.xml.
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Previous Topic:"Clear workspace" action
Next Topic:How to find out activated part upon null selection
Current Time: Sun Jul 27 13:48:11 EDT 2025
Powered by FUDForum. Page generated in 0.03425 seconds
