Home » Eclipse Projects » EclipseLink » Problems Executing Stored Procedure in DB2 with EclipseLink v1.2
Problems Executing Stored Procedure in DB2 with EclipseLink v1.2 [message #664167] |
Thu, 07 April 2011 13:14  |
I am having an issue executing a stored procedure using Eclipselink v1.2 running on Weblogic 10.0 (JDK 5) and DB2 v9.1 on z/OS. I have the following stored procedure:
CREATE PROCEDURE
PROD.SUBS
(IN GROUP_ID_VAR DECIMAL(10)
,OUT SQLCODE_OUT INTEGER
) VERSION VERSION1
LANGUAGE SQL
VALIDATE BIND
DYNAMICRULES BIND
QUALIFIER YUT
DISABLE DEBUG MODE
DYNAMIC RESULT SET 1
ASUTIME NO LIMIT
COMMIT ON RETURN NO
P1: BEGIN
DECLARE SQLCODE INT;
DECLARE TEMP_GROUP_ID DEC (10);
--DECLARE SUB_COUNT INT;
DECLARE ESA CURSOR WITH RETURN FOR
... SOME BORING SQL
OPEN ESA;
SET SQLCODE_OUT = SQLCODE;
END P1
I am executing this via a NamedStoredProcedure annotation :
@NamedStoredProcedureQueries( {
@NamedStoredProcedureQuery(
name="subs",
procedureName="PROD.SUBS",
returnsResultSet=true,
parameters={
@StoredProcedureParameter(queryParameter="groupIdVar",direction=Direction.IN,type=BigDecimal.class),
@StoredProcedureParameter(queryParameter="sqlCodeOut",direction=Direction.OUT,type=Integer.class)
resultClass=Subs.class,
resultSetMapping="subsResult"
@SqlResultSetMapping( name="subsResult", entities={
@EntityResult( entityClass=Subs.class , fields = {
@FieldResult( name="firstName", column="FIRSTNAME" ),
@FieldResult( name="lastName", column="LASTNAME" ),
@FieldResult( name="streetAddressLine1", column="STREET" ),
@FieldResult( name="streetAddressLine2", column="STREETNUMBER" ),
@FieldResult( name="city", column="CITY" ),
@FieldResult( name="state", column="STATE" ),
@FieldResult( name="zipCode", column="ZIPCODE" ),
@FieldResult( name="country", column="COUNTRY" ),
@FieldResult( name="dayPhone", column="BUSINESSPHONE" ),
@FieldResult( name="evePhone", column="PRIVATEPHONE" ),
@FieldResult( name="email", column="EMAIL" )
The interesting bit is the following:
This is being executed from a JPA Controller via the following:
EntityManager em = null;
try {
em = getEntityManager();
Query q = em.createNamedQuery( "subs" );
q.setParameter( "groupIdVar", new BigDecimal(groupId) );
Subs subs = (Subs)q.getSingleResult();
} catch( Exception e ) {
e.printStackTrace();
When I am running the query I get the following error:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 1.2.0.v20091016-r5565): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: com.ibm.db2.jcc.b.eo: [jcc][10413][10940][3.53.95] Literal replacement parsing failed for procedure call to DB2 for z/OS. Failing SQL text CALL PROD.SUBS(groupIdVar = ?, sqlCodeOut = ?). ERRORCODE=-4463, SQLSTATE=42601
Error Code: -4463
Call: CALL PROD.SUBS(groupIdVar = ?, sqlCodeOut = ?)
bind => [13488062, => sqlCodeOut]
Query: ReadAllQuery(name="subs" referenceClass=Subs )
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:333)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.processExceptionForCommError(DatabaseAccessor.java:1411)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:677)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:528)
at org.eclipse.persistence.sessions.server.ServerSession.executeCall(ServerSession.java:529)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:205)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:191)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeSelectCall(DatasourceCallQueryMechanism.java:262)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.selectAllRows(DatasourceCallQueryMechanism.java:599)
at org.eclipse.persistence.queries.ReadAllQuery.executeObjectLevelReadQuery(ReadAllQuery.java:455)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:997)
at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:670)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:958)
at org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAllQuery.java:432)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1021)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2858)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1225)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1299)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1207)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1181)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.executeReadQuery(EJBQueryImpl.java:420)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.getSingleResult(EJBQueryImpl.java:669)
As I am not sure exactly what SQL that EclipseLink is generating, because the correct syntax for executing a stored procedure in DB2 is :
I have tried using specifying the name of the parameters with the same result.
Can anyone shed some light on success/failure with executing stored procedures to DB2?
Thank you,
Chuck
Re: Problems Executing Stored Procedure in DB2 with EclipseLink v1.2 [message #753547 is a reply to message #753475] |
Thu, 27 October 2011 11:59  |
This thread was about a problem executing a stored procedure, while your problem seems to be with building the results afterward using a SQLResultSetMapping and so likely are not related. You might want to post the problem, the query and the generated SQL using EclipseLink logging set to finest in a new thread. Not much can be said on what is going wrong without information on how you set up the query and set it to use the SQLResultSetMapping you have defined.
Best Regards,
Chris
Current Time: Wed Jul 23 18:23:03 EDT 2025
Powered by FUDForum. Page generated in 0.03455 seconds
