Continuation symbol [message #662854] |
Fri, 01 April 2011 05:00  |
I have just tried Papyrus v1.12.3 and, in the palette of sequence diagram, lost and found messages are missing. I also used Papyrus via Eclipse Modeling Project, and I could find lost and found messages in the palette, but there are different features in this version. In my case, I need to use continuation, and it is only allowed inside the ALT combined fragment while I do need it outside the fragment and within ASSERT fragment.
To sum up, I need lost and found messages in sequence diagram palette, and continuation symbol allowed outside ALT fragment. Could I get some help?
Thanks so much
[Updated on: Tue, 05 April 2011 03:31] by Moderator
Re: Palette [message #665065 is a reply to message #664150] |
Wed, 13 April 2011 03:41  |
Miriam wrote on Thu, 07 April 2011 12:09 | Does Papyrus support that (displaying diagram from the *.uml?).
Generally, Papyrus should support drag and drop of a uml element from the Model Explorer view to the diagram.
But this is not always the case (there may be some bugs in some diagrams or missing implementations), and it is enabled only if the element can be actually drawn in the diagram. Which, for your situation, I suspect is not the case...
FUDForum. Page generated in 0.05351 seconds
