Adding deployment info to J2EE Preview server: realms/users and env-entry [message #664048] |
Thu, 07 April 2011 05:54  |
I've developed a small webservice whose runtime config requires
deployment information : binding env-entry to the naming context and
mapping users to roles.
My target deployment is not supported by WTP, so i could use Tomcat
but the embedded J2EE preview seems all I need,
except that I can't see how to add the deployment info.
out of the box I get HTTP 500 and NPEs ...
Edoardo
<body><h2>HTTP ERROR 500</h2>
<p>Problem accessing .... Reason:
<pre> No realm</pre>
javax.naming.NoInitialContextException: Failed to create InitialContext
using factory specified in hashtable {} [Root exception is
java.lang.NullPointerException]
at javax.naming.spi.NamingManager.getInitialContext(NamingManag er.java:243)
at
javax.naming.InitialContext.initializeDefaultInitCtx(Initial Context.java:318)
at javax.naming.InitialContext.getDefaultInitCtx(InitialContext .java:348)
at
javax.naming.InitialContext.getURLOrDefaultInitCtx(InitialCo ntext.java:424)
at javax.naming.InitialContext.lookup(InitialContext.java:436)
at javax.naming.spi.NamingManager.getInitialContext(NamingManag er.java:235)
... 29 more
Re: Adding deployment info to J2EE Preview server: realms/users and env-entry [message #664096 is a reply to message #664048] |
Thu, 07 April 2011 09:11  |
On 4/7/2011 5:54 AM, Edoardo Comar wrote:
> Hi
> Thanks
> Edoardo
> at
> at
> ... 29 more
I don't believe the J2EE Preview server provides much in the way of user
configurability. You are welcome to start the server, switch to the
Debug view in the Debug perspective, then right-click on the "Java"
executable item and select Properties. The dialog that appears will
show you the "Java" command used to launch the server. I suspect the
"preview.xml" used to configure the Jetty server is internally generated
and rewritten on each startup. You will likely be better off using
Tomcat or some other server that provides sufficient configurability.
Larry
FUDForum. Page generated in 0.03888 seconds
