Home » Modeling » EMF » Building a large XSD Schemas with annotations
Building a large XSD Schemas with annotations [message #663717] Wed, 06 April 2011 06:01 Go to next message
Hello all,
I'm working on EMF-driven model for Smooks EDI parser (http://www.smooks.org ).
We are parsing UN/EDIFACT definitions files and transforming them into model, later on model got stored as XSD so that XML describing that model can be validated.
I am using EcoreSchemaBuilder to transform my schema:
https://github.com/smooks/smooks/blob/master/edi/ect/src/mai n/java/org/milyn/ect/ecore/SchemaConverter.java#L109
I noticed when I'm creating large XSD file (with 336 classifiers with 1155 structural features) and saving it, it might take up to several minutes on modern Mac.
I did an investigation with Yourkit and it showed that most of the time the issue was in generated annotations.
In the resulting XSD I wanted to see the "ecore" annotations so that later on I would be able to reconstruct the model back from XSD and I also have my custom annotations on the model which I would like to see in XSD.
However rendering of annotations takes too much time (and memory) so by disabling annotation processing I was able to reduce time from several minutes to several seconds.
I switched off couple of methods:
https://github.com/smooks/smooks/blob/master/edi/ect/src/mai n/java/org/milyn/ect/ecore/CustomSchemaBuilder.java
However that's not the acceptable solution for me.
Is there any possible solution that would allow me to serialize ECORE to XSD quickly and reliably?
Renat
Re: Building a large XSD Schemas with annotations [message #663873 is a reply to message #663717] Wed, 06 April 2011 12:43 Go to previous messageGo to next message
Renat,
Comments below.
Renat Zubairov wrote:
> Hello all,
> time the issue was in generated annotations. In the resulting XSD I
It does indeed do a serious amount of work every time the DOM is
changed. There's a listener that wants to update the associated schema
components and then a full analysis of the whole schema is triggered...
I'm not sure what to suggest. There's currently no ability to just turn
off the event listener, which probably would be a reasonable thing to
employ in this case, i.e., when DOM changes are known not to
significantly impact the schema model. Or perhaps a mode where
non-schema namespace attributes changes (other than xmlns ones) would be
ignored...
> Renat
Re: Building a large XSD Schemas with annotations [message #663944 is a reply to message #663873] Wed, 06 April 2011 17:29 Go to previous messageGo to next message
Hello Ed,
Thnx for the answer. My comments below:
Could you please elaborate more on that, I was trying to understand what it does, any explanation would be appreciated.
ignored...
I can do that. Just need to understand what this listener does, and why it takes so much time and resources.
P.S. Nobody uses/generating large XSD schemas with EMF? Strange.
Re: Building a large XSD Schemas with annotations [message #663952 is a reply to message #663944] Wed, 06 April 2011 17:52 Go to previous message
--------------030507090309010305060608
Renat,
Comments below.
> Hello Ed,
> Quote:
>> schema components and then a full analysis of the whole schema is
>> triggered...
Look in XSDSchemaImpl at this. If you set a breakpoint in the
handleEvent, you'll see it triggers a *huge *cascade of processing.
protected EventListener getEventListener()
if (eventListener == null)
class XSDSchemaEventListener implements EventListener,
Serializable
private static final long serialVersionUID = 1L;
public void handleEvent(Event event)
if (event instanceof MutationEvent)
> Quote:
>> There's currently no ability to just turn off the event listener,
>> which probably would be a reasonable thing to employ in this case,
>> i.e., when DOM changes are known not to significantly impact the
>> schema model. Or perhaps a mode where non-schema namespace attributes
>> changes (other than xmlns ones) would be ignored...
I doubt much can be done without messing deeply with the schema model's
implementation.
I don't imagine folks change their models so often that a few minutes
for a large schema is a big concern...
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Renat,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:inilii$t7u$1@news.eclipse.org" type="cite">Hello
Ed,
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">It does indeed do a serious amount of work
every time the DOM is changed. There's a listener that wants to update
the associated schema components and then a full analysis of the whole
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
handleEvent, you'll see it triggers a <b>huge </b>cascade of
processing.<br>
<blockquote><small>  protected EventListener getEventListener()</small><br>
<small>  {</small><br>
<small>    if (eventListener == null)</small><br>
<small>      class XSDSchemaEventListener implements EventListener,
Serializable</small><br>
<small>        private static final long serialVersionUID = 1L;</small><br>
<br>
<small>        public void handleEvent(Event event) </small><br>
<small>          if (event instanceof MutationEvent)</small><br>
</blockquote>
<blockquote cite="mid:inilii$t7u$1@news.eclipse.org" type="cite"><br>
<br>
<blockquote type="cite">There's currently no ability to just turn off
be ignored...
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
implementation.<br>
<br>
</blockquote>
for a large schema is a big concern...<br>
</body>
</html>
--------------030507090309010305060608--
Previous Topic:jpa.teno-Annotation => persistence-mapping-hibernate
Next Topic:[CDO] Database backup/restore on server side
Current Time: Mon Jul 21 00:26:28 EDT 2025
Powered by FUDForum. Page generated in 0.03377 seconds
