Home » Eclipse Projects » GEF » [ZEST] Plugin View Example
[ZEST] Plugin View Example [message #246027] Fri, 31 October 2008 10:33 Go to next message
i want to make a graph Visualization from a UML Model. The Part to get
the Information from UML is already done. But i dont know to put this
together for a Plugin with a View. The Incubator Visualization is too
complicated for me. Has anyone a simpler Example for me?
Thank you and sorry for my english!
Peter
Re: [ZEST] Plugin View Example [message #246125 is a reply to message #246027] Thu, 06 November 2008 12:12 Go to previous messageGo to next message
Originally posted by: irbull.cs.uvic.ca
Peter,
Understanding Eclipse plug-ins can be a bit tricky. Have you stepped
through a simple plug-in Example. If you create a Plug-in project, and
select a template (a plug-in with a view), this should help get you
started. Of course, this is not a graphical plug-in, but the PDE viz
was based on this. Once you understand this, you can see how Zest fits
into the picture. (See the Zest snippets for other Zest examples).
cheers,
ian
Peter wrote:
> Peter
Re: [ZEST] Plugin View Example [message #663580 is a reply to message #246125] Tue, 05 April 2011 13:10 Go to previous messageGo to next message
hello ian,
I want to test the example of UML with zest and it does'nt work I don't know what's the problem !
I copied the code from this site : http://dev.eclipse.org/viewcvs/viewvc.cgi/org.eclipse.gef/te st/org.eclipse.zest.tests/src/org/eclipse/zest/tests/uml/?ro ot=Tools_Project
and i have this error when I run the program :
Exception in thread "main" java.lang.IllegalArgumentException: Argument cannot be null
at org.eclipse.swt.SWT.error(SWT.java:4064)
at org.eclipse.swt.SWT.error(SWT.java:3998)
at org.eclipse.swt.SWT.error(SWT.java:3969)
at org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java:1 28)
at org.eclipse.swt.graphics.ImageDataLoader.load(ImageDataLoade r.java:22)
at org.eclipse.swt.graphics.ImageData.<init>(ImageData.java:331)
at org.eclipse.swt.graphics.Image.<init>(Image.java:503)
at testuml.UMLExample.main(UMLExample.java:96)
thank you in advance for helping me to understand the problem
Re: [ZEST] Plugin View Example [message #663915 is a reply to message #663580] Wed, 06 April 2011 15:41 Go to previous messageGo to next message
Sounds like it's looking for icons that are not present in your setup. You should check out the entire project, not just the source files (see http://wiki.eclipse.org/CVS_Howto).
Re: [ZEST] Plugin View Example [message #663928 is a reply to message #663915] Wed, 06 April 2011 16:25 Go to previous message
thank you for your answer
I realised that the problem lay in the icons but I've downloaded the 3 images and I've put them at the root of my project . But the problem is that I forgot the "/" when writing the path of my icon Very Happy
again thank you so much
Previous Topic:Property Sheet
Next Topic:Create a window setting
Current Time: Sat Jul 19 03:02:13 EDT 2025
Powered by FUDForum. Page generated in 0.04129 seconds
