Home » Modeling » GMF (Graphical Modeling Framework) » Refresh RootEditPart
Refresh RootEditPart [message #663821] Wed, 06 April 2011 10:30 Go to next message
I have a custom layer on my
org.eclipse.gmf.runtime.diagram.ui.editparts.DiagramEditPart ,
I tried everything to refresh and show its figure, but it only refreshes
when i add or move something, and also when I resize the editor area, of
course.
Any hints?
my createFigure() and getContentPane():
* Replaces default figure with layered pane. Lower layer for
decorations, upper is original figure.
protected IFigure createFigure() {
FreeformLayeredPane pane = new FreeformLayeredPane();
FreeformLayer roseLayer = new FreeformLayer() {
public Rectangle getFreeformExtent() {
// Do not count children; they are decorations that
should not interfere with diagram contents.
Insets insets = getInsets();
return new Rectangle(0, 0, insets.getWidth(),
insets.getHeight());
roseLayer.setLayoutManager(new StackLayout());
pane.add(roseLayer);
roseLayer.add(new Figure() {
public void paint(Graphics g) {
g.setLineWidth(1);
g.setForegroundColor(new Color(null, 100, 100, 100));
DiagramImpl d = (DiagramImpl) getModel();
Sketch s = ((Diagram) d.getElement()).getRootSketch();
if (s != null) {
for (int i = 1; i < s.getPointlist().size(); i++) {
Point p = (Point) s.getPointlist().get(i);
Point lastp = p;
lastp = (Point) s.getPointlist().get(i - 1);
if (lastp.x == -1) {
//if the last point is a pen lift, then
consider just the current one
g.drawLine(p.x, p.y, p.x, p.y);
} else if (p.x > 0) {
//if is a normal point, then traces a line
from the last point to the current
g.drawLine(lastp.x, lastp.y, p.x, p.y);
pane.add(contentPane = super.createFigure());
return pane;
public IFigure getContentPane() {
return contentPane;
Re: Refresh RootEditPart [message #664674 is a reply to message #663821] Mon, 11 April 2011 10:49 Go to previous messageGo to next message
Nobody?
> refreshes when i add or move something, and also when I resize the
> editor area, of course.
> Any hints?
> @Override
> @Override
> g.setLineWidth(1);
> if (s != null) {
> Point lastp = p;
> return pane;
> @Override
> return contentPane;
Re: Refresh RootEditPart [message #664679 is a reply to message #664674] Mon, 11 April 2011 11:06 Go to previous messageGo to next message
HI,
may be sthis link could help you :
http://www.eclipse.org/forums/index.php?t=msg&goto=17663 1&S=d407a8cee29e2c8d83a8478067722c4c#msg_176631
Re: Refresh RootEditPart [message #666062 is a reply to message #663821] Mon, 18 April 2011 16:06 Go to previous messageGo to next message
Hi, did you refresh the diagram (as DiagramEditPart.refresh()) at the
end of after your code, if it doesnt work maybe try to refresh all children
for(Object o : yourDiagramEditPart.getChildren()){
if(o instanceof EditPart){//or ur costumized EditPart
EditPart editPart = (EditPart)o;
editPart.refresh();
maybe u have to go deeper in the childrentree.
I had a problem like this before, that some labels didnt refresh, so i
had to refresh the LabelEditParts children of the Figures in the diagram.
Am 06.04.2011 16:30, schrieb Ugo Sangiorgi:
> course.
> Any hints?
> @Override
> // Do not count children; they are decorations that should not interfere
> @Override
> g.setLineWidth(1);
> if (s != null) {
> Point lastp = p;
> //if the last point is a pen lift, then consider just the current one
> //if is a normal point, then traces a line from the last point to the
> current
> return pane;
> @Override
> return contentPane;
Re: Refresh RootEditPart [message #666113 is a reply to message #666062] Tue, 19 April 2011 03:54 Go to previous messageGo to next message
check this link
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281014
Re: Refresh RootEditPart [message #666600 is a reply to message #666062] Thu, 21 April 2011 05:21 Go to previous messageGo to next message
Hello Robin,
thank you, but actually my editor starts with no editparts at all. I
write some freehand drawn pixels at the RootEditPart and want it to be
displayed.
If I resize the editor, the RootEditPart is refreshed and shows the
drawing.
I just want to activate that =(
> children
> editPart.refresh();
>> course.
>> Any hints?
>> @Override
>> @Override
>> g.setLineWidth(1);
>> if (s != null) {
>> Point lastp = p;
>> current
>> return pane;
>> @Override
>> return contentPane;
Re: Refresh RootEditPart [message #666603 is a reply to message #666113] Thu, 21 April 2011 05:36 Go to previous messageGo to next message
Le 19/04/11 09:54, Sophia a écrit :
> check this link
Thank you Sophia,
I've tried to remove the semanticHints, apparently it did nothing.
Also, i tried to refresh the editpolicies, see:
EObject modelElement = ((View)
(editor.getDiagramEditPart().getModel())).getElement();
List editPolicies =
CanonicalEditPolicy.getRegisteredEditPolicies(modelElement);
for (Iterator it = editPolicies.iterator(); it.hasNext();) {
DiagramCanonicalEditPolicy nextEditPolicy =
(DiagramCanonicalEditPolicy) it
.next();
nextEditPolicy.activate();
nextEditPolicy.getViewer().getControl().redraw();
nextEditPolicy.refresh();
but nothing
Re: Refresh RootEditPart [message #666783 is a reply to message #663821] Fri, 22 April 2011 10:28 Go to previous messageGo to next message
What is even more weird is that:
When I open the diagram it doesnt show anything, only if I resize the
editor area.
Then the next drawings shows up normally, the editor is refreshed and all.
What could be hapening? How can I tell that the editor needs to be
repainted upfront?
> Any hints?
> @Override
> @Override
> g.setLineWidth(1);
> if (s != null) {
> Point lastp = p;
> return pane;
> @Override
> return contentPane;
Re: Refresh RootEditPart [SOLVED] [message #667045 is a reply to message #666783] Tue, 26 April 2011 03:57 Go to previous message
I did solved.
My DiagramEditPart reads the model (which has some x,y points) and draws
them accordingly:
private IFigure contentPane;
FreeformLayer sketchLayer = new FreeformLayer() {
sketchLayer.setLayoutManager(new StackLayout());
pane.add(sketchLayer);
sketchLayer.add(new Figure() {
[here i draw whatever i want]
return pane;
I just neeeded to refresh through a request, with this the editpart is
refreshed upon creation:
performRequest(new Request(RequestConstants.REQ_REFRESH));
return contentPane;
Outside the DiagramEditPart I just performed the refresh request:
editor.getDiagramEditPart().performRequest(new
Thats it =)
> editor area.
> all.
> repainted upfront?
>> Any hints?
>> @Override
>> @Override
>> g.setLineWidth(1);
>> if (s != null) {
>> Point lastp = p;
>> line from the last point to the current
>> return pane;
>> @Override
>> return contentPane;
Previous Topic:Drag and Drop Java files
Next Topic:[SOLVED] How to programmatically set the location of a label?
Current Time: Tue Jul 22 23:01:47 EDT 2025
Powered by FUDForum. Page generated in 1.07203 seconds
