Home » Modeling » OCL » Re: model query
Re: model query [message #663819] Wed, 06 April 2011 10:49 Go to next message
Chuck,
This sounds more likely to be an OCL question so I've added the OCL
newsgroup/forum to the to list of my reply.
chuck wrote:
> hello guys!
> i'm using model query to do some queries and update on my model...
> the steps that i done, are:
> -generate from genmodel of my metamodel every model classes ...
> -register metamodel and after call a method that has to read a model...
> -in this method :
> ResourceSet resourceSet = new ResourceSetImpl();
> URI modelUri = URI.createFileURI(new
> File("model/mymodel.ecore").getAbsolutePath());
> EcoreResourceFactoryImpl ecoreFactory = new
> EcoreResourceFactoryImpl();
> resourceSet.getResourceFactoryRegistry().getExtensionToFacto
> ryMap().put( "ecore", ecoreFactory);
> // Demand load resource for this file.
> Resource resource = resourceSet.getResource(modelUri, true);
> System.out.println("Loaded " + modelUri);
> OCL ocl = org.eclipse.ocl.ecore.OCL.newInstance();
> EObjectCondition condition = new
> BooleanOCLCondition<EClassifier, EClass, EObject>(
> ocl.getEnvironment(), "self.elements", MyMMPackage.Literals.MOD);
> SELECT statement = new SELECT(SELECT.UNBOUNDED, false, new
> FROM(resource.getContents()), new WHERE(condition));
> IQueryResult results = statement.execute(); // do something with the
> results
> System.out.println("SIZE: " + results.size());
> but i receive error like that: java.lang.ClassCastException:
> org.eclipse.emf.ecore.impl.EFactoryImpl cannot be cast to
> MyMM.MyMMFactory
> the problem is solved if I change query from "self.elements" to for
> example self.oclIsTypeOf("MyMM::metaclass")
> what it's wrong?!?!?
> thx
Re: model query [message #663828 is a reply to message #663819] Wed, 06 April 2011 11:19 Go to previous messageGo to next message
Chuck,
(Ed, thanks for forwarding)
not sure if you attached a stack trace for the class case exception to the original post, but it's not in here. Could you please post it here so we can see where things fail exactly? Also, can you give us a few clues as to the type of the feature that "self.elements" navigates?
-- Axel
Re: model query [message #663833 is a reply to message #663819] Wed, 06 April 2011 11:21 Go to previous messageGo to next message
BTW, one more hint: I suppose that self.elements does not evaluate to a Boolean, does it? According to my understanding of BooleanOCLCondition it should evaluate to a Boolean value.
Re: model query [message #663844 is a reply to message #663819] Wed, 06 April 2011 11:47 Go to previous message
This isn't actually an OCL problem, but an EMF Query issue.
As Axel observes, you may not be using Boolean. The CCE certainly looks
like a data type construction issue, but since you only provide 25% of
the problem report we can only provide 25% of the answer.
Ed Willink
On 06/04/2011 15:49, Ed Merks wrote:
> Chuck,
> chuck wrote:
>> hello guys!
>> -in this method :
>> results
>> MyMM.MyMMFactory
>> thx
Previous Topic:Evaluate Ecore Instances programatically
Next Topic:Permanent violation of invariants after closing and opening the validated file
Current Time: Tue Jul 22 23:02:34 EDT 2025
Powered by FUDForum. Page generated in 0.04326 seconds
