Home » Archived » Buckminster » The application will not start after update...
The application will not start after update... [message #662249] Tue, 29 March 2011 17:08 Go to next message
Hi!
I have a problem with Update.
I have a project consisting of plugins and features:
+ Org.update.test.plugin
update.product
p2.inf
+ Org.update.test.feature
feature.xml
+ Org.update.test.site
+ Build
product.ant
feature.xml
buckminster.cspex
site.cquery
site.rmap
In backminster.cspex commands are defined and create.product create.product.zip (ie, all as described in the tutorial http://www.ralfebert.de/blog/eclipsercp/rcp_builds/)
Construction works fine, but suddenly starts after an update no longer my application.
I have noticed that after the update in config.ini disappeared all start commands for OSGI bundles and some fields such as eclipse.product or eclipse.application are empty.
Config.ini looks like that: ( its from Eclipse IDE, tomorrow will send more data of my application config.ini)
before:
# Tue Mar 29 21:45:27 PDT 2011
org.eclipse.update.reconcile = false
eclipse.p2.profile = epp.package.java
osgi.instance.area.default = @ user.home / workspace
osgi.framework = file \: plugins/org.eclipse.osgi_3.6.2.R36x_v20110210.jar
equinox.use.ds = true
eclipse.buildId = M20110210-1200
osgi.bundles = reference \: file \: org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503.jar @ 1 \: start
org.eclipse.equinox.simpleconfigurator.configUrl = file \: org.eclipse.equinox.simpleconfigurator / bundles.info
eclipse.product = ru.update.test.product
osgi.splashPath =
osgi.framework.extensions =
osgi.bundles.defaultStartLevel = 4
eclipse.application = ru.update.test.application
eclipse.p2.data.area = @ config.dir/../p2 /
After:
eclipse.product =
osgi.splashPath =
am grateful for every tip
Re: The application will not start after update... [message #662320 is a reply to message #662249] Wed, 30 March 2011 05:05 Go to previous messageGo to next message
Here are config.ini before and after:
Before
# This configuration file was written by: org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxF wConfigFileParser
# Tue Mar 29 10:17:11 PDT 2011
eclipse.p2.profile = Updateprofile
osgi.framework = file \: plugins/org.eclipse.osgi_3.6.1.R36x_v20100806.jar
eclipse.product = com.update.test.product
osgi.splashPath = platform \: / base / plugins / com.update.test
eclipse.application = com.update.test.application
and after:
# Wed Mar 30 09:40:35 PDT 2011
osgi.bundles = reference \: file \: @ 4 org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503.jar , reference \: file \: @ 4 ca.odell.glazedlists_1.8.0.alpha20110124.jar, reference \: f
eclipse.product =
osgi.splashPath =
In addition, the files eclipsec.exe and Update.ini disappeared.
Logfile:
!SESSION 2011-03-30 11:03:35.127 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_23
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2 0 2011-03-30 11:03:57.283
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2011-03-30 11:03:57.283
!MESSAGE Bundle com.update.test_1.0.0.201103291011 [11] was not resolved.
!SUBENTRY 2 com.update.test 2 0 2011-03-30 11:03:57.283
!MESSAGE Another singleton version selected: com.update.test_1.0.0.201103300913
!MESSAGE Bundle com.update.test.avldsl_1.0.0.201103291010 [12] was not resolved.
!SUBENTRY 2 com.update.test.avldsl 2 0 2011-03-30 11:03:57.283
!MESSAGE Missing optionally required bundle org.eclipse.xtext.generator_[1.0.0,2.0.0).
!MESSAGE Bundle com.update.test.avldsl.generator_1.0.0.201103291010 [13] was not resolved.
!SUBENTRY 2 com.update.test.avldsl.generator 2 0 2011-03-30 11:03:57.283
!MESSAGE Another singleton version selected: com.update.test.avldsl.generator_1.0.0.201103300913
!MESSAGE Bundle com.update.test.avldsl.ui_1.0.0.201103291010 [14] was not resolved.
!SUBENTRY 2 com.update.test.avldsl.ui 2 0 2011-03-30 11:03:57.283
!MESSAGE Another singleton version selected: com.update.test.avldsl.ui_1.0.0.201103300913
!MESSAGE Bundle com.update.test.compiler_1.0.0.201103291010 [15] was not resolved.
!SUBENTRY 2 com.update.test.compiler 2 0 2011-03-30 11:03:57.283
!MESSAGE Another singleton version selected: com.update.test.compiler_1.0.0.201103300913
!MESSAGE Bundle com.update.test.dicoreconnector_1.0.0.201103291010 [16] was not resolved.
!SUBENTRY 2 com.update.test.dicoreconnector 2 0 2011-03-30 11:03:57.283
!MESSAGE Another singleton version selected: com.update.test.dicoreconnector_1.0.0.201103300913
!MESSAGE Bundle com.update.test.ecud_1.0.0.201103291010 [17] was not resolved.
!SUBENTRY 2 com.update.test.ecud 2 0 2011-03-30 11:03:57.283
!MESSAGE Bundle com.update.test.ecud.generator_1.0.0.201103291010 [18] was not resolved.
!SUBENTRY 2 com.update.test.ecud.generator 2 0 2011-03-30 11:03:57.283
!MESSAGE Another singleton version selected: com.update.test.ecud.generator_1.0.0.201103300913
!MESSAGE Bundle com.update.test.ecud.ui_1.0.0.201103291010 [19] was not resolved.
!SUBENTRY 2 com.update.test.ecud.ui 2 0 2011-03-30 11:03:57.283
!MESSAGE Another singleton version selected: com.update.test.ecud.ui_1.0.0.201103300913
!MESSAGE Bundle com.update.test.flow_1.0.0.201103291010 [20] was not resolved.
!SUBENTRY 2 com.update.test.flow 2 0 2011-03-30 11:03:57.283
!MESSAGE Bundle com.update.test.flow.generator_1.0.0.201103291010 [21] was not resolved.
!SUBENTRY 2 com.update.test.flow.generator 2 0 2011-03-30 11:03:57.283
!MESSAGE Another singleton version selected: com.update.test.flow.generator_1.0.0.201103300913
!MESSAGE Bundle com.update.test.flow.ui_1.0.0.201103291010 [22] was not resolved.
!SUBENTRY 2 com.update.test.flow.ui 2 0 2011-03-30 11:03:57.283
!MESSAGE Another singleton version selected: com.update.test.flow.ui_1.0.0.201103300913
!MESSAGE Bundle com.update.test.localcache_1.0.0.201103291011 [23] was not resolved.
!SUBENTRY 2 com.update.test.localcache 2 0 2011-03-30 11:03:57.283
!MESSAGE Another singleton version selected: com.update.test.localcache_1.0.0.201103300913
!MESSAGE Bundle com.update.test.logproperties_1.0.0.201103291009 [24] was not resolved.
!MESSAGE Bundle com.update.test.mapping_1.0.0.201103291010 [25] was not resolved.
!SUBENTRY 2 com.update.test.mapping 2 0 2011-03-30 11:03:57.283
!MESSAGE Another singleton version selected: com.update.test.mapping_1.0.0.201103300913
!MESSAGE Bundle com.update.test.multipage_1.0.0.201103291010 [28] was not resolved.
!SUBENTRY 2 com.update.test.multipage 2 0 2011-03-30 11:03:57.283
!MESSAGE Another singleton version selected: com.update.test.multipage_1.0.0.201103300913
!MESSAGE Bundle com.update.test.odx.generator_1.0.0.201103291010 [29] was not resolved.
!SUBENTRY 2 com.update.test.odx.generator 2 0 2011-03-30 11:03:57.283
!MESSAGE Another singleton version selected: com.update.test.odx.generator_1.0.0.201103300913
!MESSAGE Bundle com.update.test.translation_1.0.0.201103291010 [30] was not resolved.
!SUBENTRY 2 com.update.test.translation 2 0 2011-03-30 11:03:57.283
!MESSAGE Another singleton version selected: com.update.test.translation_1.0.0.201103300913
!MESSAGE Bundle com.update.test.xmlpreview_1.0.0.201103291010 [31] was not resolved.
!SUBENTRY 2 com.update.test.xmlpreview 2 0 2011-03-30 11:03:57.283
!MESSAGE Another singleton version selected: com.update.test.xmlpreview_1.0.0.201103300913
!ENTRY org.eclipse.osgi 4 0 2011-03-30 11:03:57.299
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
[Updated on: Mon, 11 April 2011 03:38] by Moderator
Re: The application will not start after update... [message #662370 is a reply to message #662249] Wed, 30 March 2011 08:17 Go to previous messageGo to next message
What is it that you are updating?
Your IDE/Buckminster? (and it produces something different after this
update)?
or
An update of your installed RCP application? If so, how did you perform
that update (self update or via the director)?
- henrik
On 3/29/11 11:08 PM, Alex wrote:
> Hi! I have a problem with Update.
> + Org.update.test.plugin ... update.product p2.inf ... +
> Org.update.test.feature feature.xml + Org.update.test.site + Build
> product.ant feature.xml buckminster.cspex site.cquery site.rmap In
> my application.
> before:
> # Tue Mar 29 21:45:27 PDT 2011 org.eclipse.update.reconcile = false
> eclipse.p2.profile = epp.package.java osgi.instance.area.default = @
> user.home / workspace osgi.framework = file \:
> plugins/org.eclipse.osgi_3.6.2.R36x_v20110210.jar equinox.use.ds = true
> eclipse.buildId = M20110210-1200 osgi.bundles = reference \: file \:
> start org.eclipse.equinox.simpleconfigurator.configUrl = file \:
> org.eclipse.equinox.simpleconfigurator / bundles.info ...
> eclipse.product = ru.update.test.product osgi.splashPath =
> osgi.framework.extensions = osgi.bundles.defaultStartLevel = 4
> eclipse.application = ru.update.test.application eclipse.p2.data.area =
> After:
> eclipse.p2.profile = osgi.instance.area.default = @ user.home /
> org.eclipse.equinox.simpleconfigurator_1.0.200.v2010050 ...
> eclipse.product = osgi.splashPath = osgi.framework.extensions =
> osgi.bundles.defaultStartLevel = 4 eclipse.application =
Re: The application will not start after update... [message #662457 is a reply to message #662370] Wed, 30 March 2011 13:33 Go to previous messageGo to next message
Hi, Henrik
It is an installed RCP application. I Updating from the menu ...
nor is it mysteriously, when I unpack my application in different folders and launch.
Today, I have tried the application from C drive to start, then disappears UpdateTest.exe file as well.
Re: The application will not start after update... [message #662505 is a reply to message #662457] Wed, 30 March 2011 16:35 Go to previous messageGo to next message
Have you checked that what you produced was a roaming install, and that
the install was not produced using relative paths?
All sorts of weird things happen otherwise.
- henrik
On 3/30/11 7:33 PM, Alex wrote:
> Hi, Henrik
> folders and launch.
Re: The application will not start after update... [message #662562 is a reply to message #662505] Thu, 31 March 2011 03:04 Go to previous messageGo to next message
Yes, I'm sure. Here is my product.ant
<project>
	 <pathconvert property="equinox.launcher.jar">
	   <first count="1">
	     <sort>
	       <fileset dir="${eclipse.home}/plugins" includes="**/org.eclipse.equinox.launcher_*.jar"/>
	       <reverse xmlns="antlib:org.apache.tools.ant.types.resources.comparators">
	         <date/>
	       </reverse>
	     </sort>
	   </first>
	 </pathconvert>
	<target name="create.product">
		<property name="destination" location="${sp:destination}"/>
		<delete dir="${destination}"/>
		<makeurl property="repository" file="${sp:repository}"/>
		<mkdir dir="${destination}"/>
		<echoproperties/>
		<echo message="${equinox.launcher.jar}"/>
		<echo message="${repository}"/>
		<echo message="${destination}"/>
		<java jar="${equinox.launcher.jar}" fork="true" failonerror="true" >
			<arg value="-application"/>
			<arg value="org.eclipse.equinox.p2.director"/>
			<arg value="-repository"/>
			<arg value="${repository}"/>
			<arg value="-destination"/>
			<arg value="${destination}"/>
			<arg value="-profile"/>
			<arg value="${profile}"/>
			<arg value="-profileProperties" />
			<arg value="org.eclipse.update.install.features=true, org.eclipse.equinox.p2.roaming=true" />
			<arg value="-installIU"/>
			<arg value="${iu}"/>
			<arg value="-p2.os" />
			<arg value="${target.os}" />
			<arg value="-p2.ws" />
			<arg value="${target.ws}" />
			<arg value="-p2.arch" />
			<arg value="${target.arch}" />
			<arg value="-consoleLog"/>
		</java>
	</target>
</project>
Where can the relative paths occur?
Re: The application will not start after update... [message #662583 is a reply to message #662562] Thu, 31 March 2011 04:28 Go to previous messageGo to next message
That would be 'destination'. Don't think that can happen when director is
run this way. More something to watch out for when using the director on
the command line.
- henrik
Re: The application will not start after update... [message #663675 is a reply to message #662583] Wed, 06 April 2011 03:31 Go to previous messageGo to next message
I have found the cause of my problem:
I am building product for 32 and 64 bit platforms, so first site.p2 and then products separately. I use this Update-site to update my products.
perform -Dtarget.os=win32 -Dtarget.ws=win32 -Dtarget.arch=* com.update.test.site#site.p2
perform -Dtarget.os=win32 -Dtarget.ws=win32 -Dtarget.arch=x86 com.update.test.site#create.product.zip
perform -Dtarget.os=win32 -Dtarget.ws=win32 -Dtarget.arch=x86_64 com.update.test.site#create.product.zip
The problem is that every time action "create.product" call site.p2 as a Prerequisite -> which then deletes the entire directory "site.p2" and it builds again. In the end I have in site.p2 directory artifacts only for 64-bit platform.
Yesterday I tried to override site.p2 Action.(to change UpToDatePolicy to NOT_EMPTY). The directory is deleted but still every time.
Buckminster.cspex:
<cspecExtension
	xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0"
	xmlns="http://www.eclipse.org/buckminster/CSpec-1.0">
	<dependencies>
		<!-- Place your Dependencies here -->
	</dependencies>
	<generators>
		<!-- Place your Generators here -->
	</generators>
	<artifacts>
		<!-- Place your Artifacts here -->
	</artifacts>
	<actions>
	        <public name="site.p2" actor="p2SiteGenerator">
                    <prerequisites>
                       <attribute name="site.feature.exports" alias="site" filter="(&amp;(!(site.pack200=true))(!(site.signing=true)))"/>
                       <attribute name="site.packed" alias="site" filter="(site.pack200=true)"/>
                       <attribute name="site.signed" alias="site" filter="(&amp;(site.signing=true)(!(site.pack200=true)))"/>
                       <attribute name="manifest" alias="site.definer"/>
                       <attribute name="product.configuration.exports" alias="product.configs"/>
                     </prerequisites>
                   <products base="${buckminster.output}/site.p2/" upToDatePolicy="NOT_EMPTY"/>
                </public>
		<public name="create.product" actor="ant">
			<actorProperties>
				<property key="buildFile" value="build/product.ant"/>
				<property key="targets" value="create.product"/>
			</actorProperties>
			<properties>
				<property key="profile" value="UpdateProfile"/>
				<property key="iu" value="update.product"/>
			</properties>
			<prerequisites alias="repository">
				<attribute name="site.p2"/>
			</prerequisites>
			<products alias="destination" base="${buckminster.output}">
				<path path="Update.${target.ws}.${target.os}.${target.arch}/"/>
			</products>
		</public>
		<public name="create.product.zip" actor="ant">
			<actorProperties>
				<property key="buildFileId" value="buckminster.pdetasks"/>
				<property key="targets" value="create.zip"/>
			</actorProperties>
			<prerequisites alias="action.requirements">
				<attribute name="create.product"/>
			</prerequisites>
			<products alias="action.output" base="${buckminster.output}">
				<path path="Update.${target.ws}.${target.os}.${target.arch}.zip"/>
			</products>
		</public>
	</actions>
	<groups>
		<!-- Place your Groups here -->
	</groups>
	<alterDependencies>
		<!-- Place your Dependency alterations here -->
	</alterDependencies>
	<alterArtifacts>
		<!-- Place your Artifact alterations here -->
	</alterArtifacts>
	<alterActions>
		<remove name="site.p2" />
	</alterActions>
	<alterGroups>
		<!-- Place your Group alterations here -->
	</alterGroups>
</cspecExtension>
Maybe someone knows an elegant solution?
Re: The application will not start after update... [message #663679 is a reply to message #663675] Wed, 06 April 2011 03:38 Go to previous messageGo to next message
Hi Alex,
Create an two actions that calls the create product ant task with a different set of properties. Let both actions have
the site.p2 as a prerequisite. Create a group that includes those two actions. You now need one single perform call that
calls on the group and Buckminster will orchestrate the whole build. This means that the site.p2 action will only be
called once although you create two products.
HTH,
- thomas
On 2011-04-06 09:31, Alex wrote:
> every time.
> Buckminster.cspex:
> <cspecExtension
> <dependencies>
> </dependencies>
> <generators>
> </generators>
> <artifacts>
> </artifacts>
> <actions>
> <prerequisites>
> <attribute name="site.feature.exports" alias="site" filter="(&(!(site.pack200=true))(!(site.signing=true))) "/>
> <attribute name="site.signed" alias="site" filter="(&(site.signing=true)(!(site.pack200=true)))"/ >
> </prerequisites>
> </public>
> <actorProperties>
> </actorProperties>
> <properties>
> </properties>
> </prerequisites>
> </products>
> </public>
> <actorProperties>
> </actorProperties>
> </prerequisites>
> <path path="Update.${target.ws}.${target.os}.${target.arch}.zip"/ >
> </products>
> </public>
> </actions>
> <groups>
> </groups>
> <alterDependencies>
> <alterArtifacts>
> </alterArtifacts>
> <alterActions>
> </alterActions>
> <alterGroups>
> </alterGroups>
> </cspecExtension>
Re: The application will not start after update... [message #663705 is a reply to message #663679] Wed, 06 April 2011 05:25 Go to previous messageGo to next message
Hi, Thomas
Thanks for your reply.
I just tried to do what you suggested.
<cspecExtension
	<dependencies>
	</dependencies>
	<generators>
	</generators>
	<artifacts>
	</artifacts>
	<actions>
		<public name="create.product.x32" actor="ant">
			<actorProperties>
			</actorProperties>
			<properties>
				<property key="arch" value="x86"/>
				<property key="profile" value="UdateProfile"/>
			</properties>
				<attribute name="site.p2" />
			</prerequisites>
				<path path="update.${target.ws}.${target.os}.x32/"/>
			</products>
		</public>
		<public name="create.product.x64" actor="ant">
			<actorProperties>
			</actorProperties>
			<properties>
				<property key="arch" value="x86_64"/>
			</properties>
			</prerequisites>
				<path path="update.${target.ws}.${target.os}.x64/"/>
			</products>
		</public>
	</actions>
	<groups>
		<public name="product.x32.x64">
			<attribute name="create.product.x32" />
			<attribute name="create.product.x64" />
		</public>
	</groups>
	<alterDependencies>
	<alterArtifacts>
	</alterArtifacts>
	<alterActions>
	</alterActions>
	<alterGroups>
	</alterGroups>
</cspecExtension>
Site.p2 is indeed a time called, but "site.p2" directory contain artifacts only for 32-bit platform ...
If I use a filter, it is simply ingored.
			<actorProperties>
			</actorProperties>
			<properties>
			</properties>
				<attribute name="site.p2" filter="(target.arch=*)"/>
			</prerequisites>
			</products>
		</public>
Re: The application will not start after update... [message #663710 is a reply to message #663705] Wed, 06 April 2011 05:32 Go to previous messageGo to next message
Hi Alex,
What properties do you use when you execute the perform?
- thomas
On 2011-04-06 11:25, Alex wrote:
> Hi, Thomas
> <cspecExtension
> <dependencies>
> </dependencies>
> <generators>
> </generators>
> <artifacts>
> </artifacts>
> <actions>
> <actorProperties>
> </actorProperties>
> <properties>
> </properties>
> </prerequisites>
> </products>
> </public>
> <actorProperties>
> </actorProperties>
> <properties>
> </properties>
> </prerequisites>
> </products>
> </public>
> </actions>
> <groups>
> </public>
> </groups>
> <alterDependencies>
> <alterArtifacts>
> </alterArtifacts>
> <alterActions>
> </alterActions>
> <alterGroups>
> </alterGroups>
> </cspecExtension>
> <actorProperties>
> </actorProperties>
> <properties>
> </properties>
> </prerequisites>
> </products>
> </public>
Re: The application will not start after update... [message #663715 is a reply to message #663710] Wed, 06 April 2011 05:56 Go to previous messageGo to next message
Currently I use only target.os and target.ws. target.arch is explicitly specified in buckminster.cspex
import ${WORKSPACE}ru.update.site/site.cquery
build -c
perform -Dtarget.os=win32 -Dtarget.ws=win32 ru.update.site#product.x32.x64
[Updated on: Wed, 06 April 2011 05:57] by Moderator
Re: The application will not start after update... [message #663741 is a reply to message #663715] Wed, 06 April 2011 07:13 Go to previous messageGo to next message
On 2011-04-06 11:56, Alex wrote:
> Currently I use only target.os and target.ws. target.arch is explicitly buckminster.cspex
Not sure I understand. How do you set the target.arch in a cspex?
> build -c
OK, so try this instead:
perform -Dtarget.os=win32 -Dtarget.ws=win32 -Dtarget.arch=* ru.update.site#product.x32.x64
Re: The application will not start after update... [message #664564 is a reply to message #663741] Mon, 11 April 2011 04:09 Go to previous message
I just tested your suggestion, it works ...thanks Smile
Previous Topic:Cached repository meta-data
Next Topic:Problems using HelloXML example from BuckyBook
Current Time: Wed Jul 23 00:47:10 EDT 2025
Powered by FUDForum. Page generated in 0.13183 seconds
