remove command-line arguments from log file [message #663625] |
Tue, 05 April 2011 18:05  |
I was wondering if there is a way to configure what default information is written to the Eclipse log files? Specifically, I would like to not display the framework/command-line arguments. I am passing secure information between applications, and that is a problem if it appears in the log file like this.
For example, I do not want the ABC argument show up as it does below....
!ENTRY org.eclipse.equinox.registry 2 1 2011-04-04 15:58:00.039
!MESSAGE Problems parsing plug-in manifest for: "com.abc".
!SUBENTRY 1 org.eclipse.equinox.registry 2 1 2011-04-04 15:58:00.039
!MESSAGE Unknown element "requires", found within a "plugin", ignored (line: 13).
!MESSAGE Unknown element "import", found at the top level, ignored.
!ENTRY org.eclipse.ui 4 4 2011-04-04 15:58:06.336
!MESSAGE Unable to find Action Set: com.abc.ui.EditorActionSet
!SESSION 2011-04-04 15:59:33.256 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_14
Framework arguments: /ABC=123
Command-line arguments: -os win32 -ws win32 -arch x86 -clean /ABC=123
Is this even possible?
FUDForum. Page generated in 0.04298 seconds
