Home » Eclipse Projects » Rich Client Platform (RCP) » how to define activeWhen for Undo/Redo handlers
how to define activeWhen for Undo/Redo handlers [message #663613] Tue, 05 April 2011 16:46 Go to next message
I've an rcp application with the classic Edit/Undo and Edit/Redo commands.
Their activeWhen clauses look like this (undo case):
<activeWhen>
<test
property="undo.history.canUndo">
</test>
</activeWhen>
where undo.history.canUndo is a propertyTester that returns:
PlatformUI.getWorkbench().getOperationSupport().getOperation History().canUndo(myContext);
The problem is that it seems that the activeWhen clause is only
evaluated when the selection changes, and not each time the Edit menu is
opened!
If I undo an operation without changing the selection, the handler
active-state isn't refreshed and the UI goes out of sync with respect to
the canUndo/canRedo status.
How can I solve this?
How do you guys handle your Undo/Redo commands?
Carlo
Re: how to define activeWhen for Undo/Redo handlers [message #663757 is a reply to message #663613] Wed, 06 April 2011 08:29 Go to previous messageGo to next message
> opened!
Property testers aren't tied to the source providers (which provide
event driven variables for the core expressions).
You need to 1) know when that property changes and 2) call
org.eclipse.ui.services.IEvaluationService.requestEvaluation (String) to
allow users of that property to re-evaluate.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: how to define activeWhen for Undo/Redo handlers [message #663771 is a reply to message #663757] Wed, 06 April 2011 09:09 Go to previous messageGo to next message
>> opened!
> PW
It works! You made my day Paul, thanks.
P.S.
May I shamelessly ask you to give a look also to my other message titled
"problem with TriggeredOperations"? :-)
I don't understand how to undo composite operations.
Re: how to define activeWhen for Undo/Redo handlers [message #663772 is a reply to message #663771] Wed, 06 April 2011 09:13 Go to previous message
Excellent.
> P.S.
Unfortunately, neither do I :-)
Later,
PW
Paul Webster
Previous Topic:Handlers enabledWhen based on String in View
Next Topic:Adapter pattern in eclipse: is it possible to have multiple adapter factories on platform?
Current Time: Sat Jul 26 15:23:51 EDT 2025
Powered by FUDForum. Page generated in 0.06405 seconds
