Home » Eclipse Projects » Rich Client Platform (RCP) » Toolbar Change Image Command When Pressed
Toolbar Change Image Command When Pressed [message #663539] Tue, 05 April 2011 10:41 Go to next message
We're trying to achieve the following:
We have custom commands to change data in a view. These commands appear in the toolbar with an image. This works fine but when an image is clicked, a new image should appear (so the user knows which 'filter' is used). Allso just one image can appear 'pressed', because only one filter can be applied.
I hope it's clear, thanks in advance.
Re: Toolbar Change Image Command When Pressed [message #663547 is a reply to message #663539] Tue, 05 April 2011 10:55 Go to previous messageGo to next message
On 04/05/2011 10:41 AM, Ricky de Klerck wrote:
You want to add org.eclipse.ui.commands.IElementUpdater to your handler.
When it's time to update the icon for your commands, you would call
org.eclipse.ui.commands.ICommandService.refreshElements(Stri ng, Map) to
notify the framework it's time to request a UI refresh.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Toolbar Change Image Command When Pressed [message #663605 is a reply to message #663547] Tue, 05 April 2011 15:49 Go to previous messageGo to next message
Thank you for the reply, I haven't tried it yet but it sounds like this is what I need.
So I should implement the interface for every handler and call this method? Before I call this method, I should change the images for every command?
Re: Toolbar Change Image Command When Pressed [message #665483 is a reply to message #663539] Thu, 14 April 2011 14:41 Go to previous messageGo to next message
You have to implement IElementUpdater for every handler. You can change the image, text, tooltip and dropMenuDownID (if its and toolbar button) in the implemented method from IElementUpdater.
afaik it is called automatically if the handler gets executed but you have to call refreshElements if you would like to change the appearance after some underlying condition has changed.
Johan
[Updated on: Thu, 14 April 2011 14:47] by Moderator
Re: Toolbar Change Image Command When Pressed [message #666734 is a reply to message #663539] Thu, 21 April 2011 22:19 Go to previous messageGo to next message
as javadoc said IElementUpdater
Everybody should go through the
ICommandService refreshElements(*) method.
but how can i get ICommandService,and then invoke IElementUpdater
Re: Toolbar Change Image Command When Pressed [message #666807 is a reply to message #666734] Fri, 22 April 2011 13:21 Go to previous message
You can get the service from the service registry. IServiceLocator
from ViewPart
getSite().getService( ICommandService.class )
from Handler impl.
PlatformUI.getWorkbench().getService( ICommandService.class )
Johan
Previous Topic:Re-Exporting external library best practice
Next Topic:Product does not work on Mac OSX, although it runs on Windows/Linux
Current Time: Sat Jul 26 21:01:31 EDT 2025
Powered by FUDForum. Page generated in 0.06381 seconds
