Home » Archived » M2M (model-to-model transformation) » [QVTO] Mappings with non-model type context
[QVTO] Mappings with non-model type context [message #662617] Thu, 31 March 2011 06:03 Go to next message
Hi all,
I've just found out that QVTo supports using OCL types as the context of
mappings, like:
--8<---------------cut here---------------start------------->8---
transformation Nix2Genealogy(out dst:Persons);
main() {
Set{1,2,3} -> map int2Genealogy();
Set{Set{"foo", "bar"},
Set{"foo", "foo"},
Set{"bar", "bar", "baz"},
Set{"foo"},
Set{"bar", "foo"}} -> map set2Male();
mapping Integer::int2Genealogy() : Persons::Genealogy {}
mapping Set(String)::set2Male() : Persons::Male {}
--8<---------------cut here---------------end--------------->8---
I think it's a nice feature. But is that conforming to the QVT spec?
Since that defines mappings in terms of relations, I somehow don't see
how that should match. For example, the second mapping operation above
would correspond to a relation:
relation REL_set2Male {
checkonly domain:??? (self:Set(String))[]
enforce domain:dst (result:Persons::Male)[]
But I don't grasp the meaning of that relation. How can a relation hold
between a value (integer, set, whatsoever) and a model element?
Aside from the spec, I have another question. If I extend the example
above to this
// add this to main():
// Set{1,2,3} -> map int2Female();
// That does work
wife := 1.late resolveone(Female);
mapping Integer::int2Female() : Persons::Female {
// That does NOT work
// husband := Set{"foo", "foo"}.resolveone(Male);
why does the late resolve on 1 work indeed, but the other way round,
resolving a Male from a set for which a Male was created, does not work?
Bye,
Tassilo
Dipl.-Inform. Tassilo Horn | Room: B015
University of Koblenz-Landau, Campus Koblenz | Phone: +49 (261) 287-2745
Institute for Software Technology | Mail: horn@uni-koblenz.de
Universitätsstr. 1, 56070 Koblenz, Germany |
Re: [QVTO] Mappings with non-model type context [message #663443 is a reply to message #662617] Tue, 05 April 2011 02:55 Go to previous messageGo to next message
Hi Tassilo
Since no one else is answering, I'll try.
I find the use of 'relations' in the QVTo spec very unhelpful; more of
an aspiration towards QVT commonality than a practice. The examples I've
looked at just make no sense at all.
So I think kooking for a consistency with relations is inappropriate.
"map" is a useful functionality between well-defined model types and
that is what you've discovered.
I've found it very difficult to get useful results from "resolve" so I
tend to maintain my own mapping Dict. So I'm afraid that I can't suggest
whether you problem is with your understanding, the QVTo implementation
or the QVTo specification.
Ed Willink
On 31/03/2011 11:03, Tassilo Horn wrote:
> Hi all,
> mappings, like:
> main() {
> Set{"foo", "foo"},
> Set{"foo"},
> above to this
> // That does work
> Bye,
> Tassilo
Re: [QVTO] Mappings with non-model type context [message #663516 is a reply to message #663443] Tue, 05 April 2011 09:03 Go to previous message
Ed Willink <ed@willink.me.uk> writes:
Hi Ed,
> I've looked at just make no sense at all.
Yes, I have the same impression. But if they had been consequent, they
would have specified QVTo with Relations, Relations with Core, and Core
with QVTo, in order to get a nice, mutually recursive specification.
Agreed.
Yeah, but then, why is Integer well-defined, but Set(String) is not?
Really? IMO, automatic source <-> target mappings with resolving
functionality is one of the most important concepts of model
transformations. I mean, if I have to maintain those myself, I could
stick to plain Java (or whatsoever) and Map<Object, Object>.
> So I'm afraid that I can't suggest whether you problem is with your
> understanding, the QVTo implementation or the QVTo specification.
Ok, thanks anyway.
What I am really looking for is a statement from a QVTo dev, like
a) It's not really backed by the spec. That it works for Integers is
a coincidence you should not rely on.
b) It's not really backed by the spec, but we think it's useful. The
failing resolution for Sets is a bug.
c) ...
Bye,
Tassilo
>> Hi all,
>> mappings, like:
>> main() {
>> Set{"foo", "foo"},
>> Set{"foo"},
>> above to this
>> // That does work
>> Bye,
>> Tassilo
Previous Topic:[ATL] EsuperTypes and references
Next Topic:M2M gmftools
Current Time: Thu Jul 24 14:16:24 EDT 2025
Powered by FUDForum. Page generated in 0.06237 seconds
