| Build-Failure with Buckminster 3.7 on Eclipse Hudson [message #663472] |
Tue, 05 April 2011 04:53  |
I just noticed an issue with the current Buckminster 3.7 installation on the
Eclipse Hudson. About 2 weeks ago I switched my build from Buckminster 3.6
to 3.7 and it worked until April 1st (hope this is no April Fool's joke
;-) ). From that day on the build suddenly failed with with the message that
one of our source features produced by Buckminster could not be found:
Warning: file
/opt/public/jobs/gmp-graphiti-nightly/workspace/buildroot/bu ckminster.workspace/features/org.eclipse.graphiti.sdk.featur e/feature.xml,
line 54: Feature reference 'org.eclipse.graphiti.feature.examples.source'
cannot be resolved
Inspecting the log I found two previous error entries "[Fatal Error] :1:1:
Premature end of file." without more info.
After switching back to Buckminster 3.6 the build went through again without
any further changes. I'm not sure if this is an issue in Buckminster itself
or is related to the installation on Hudson. Here are the links to the build
logs:
Using Buckminster 3.6, build fine:
https://hudson.eclipse.org/hudson/me/my-views/view/Graphiti/ job/gmp-graphiti-nightly/570/console
Using Buckminster 3.7, build broken, logging set tro debug:
https://hudson.eclipse.org/hudson/me/my-views/view/Graphiti/ job/gmp-graphiti-nightly/569/console
Michael
| Re: Build-Failure with Buckminster 3.7 on Eclipse Hudson [message #663499 is a reply to message #663481] |
Tue, 05 April 2011 08:06  |
Thanks, you're right. The API baseline messages are errors now. I ignored
them because I'm used to see them for quite some time now...
Thanks for your help,
Michael
"Thomas Hallgren" wrote in message news:ineoep$ktu$1@news.eclipse.org...
Your links resulted in a 404 but this one works:
https://hudson.eclipse.org/hudson/job/gmp-graphiti-nightly/5 69/console
I don't think the warnings about the missing source features are a problem.
That's just the PDE-compiler complaining
because you reference non-existent features in your workspace. This is
normal when you have hard-coded references to
generated features. You will find the same warnings in the build that
succeeds.
The "Fatal Error] :1 :1" is ugly, but nothing to worry about. It has been
fixed and will go away when the next 3.7
milestone is released. For more info see:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=340197
The real problem seems to be related to baselines. I see lots of errors
ending with:
"An API baseline has not been set for the current workspace.". They appear
in the 3.6 build as well but there they are
just warnings. My guess is that PDE changed the default in 3.7 so that a
missing baseline is now an error.
HTH,
Thomas Hallgren
> the Eclipse Hudson. About 2 weeks ago I
> switched my build from Buckminster 3.6 to 3.7 and it worked until April
> 1st (hope this is no April Fool's joke ;-) ).
> From that day on the build suddenly failed with with the message that one
> Warning: file
> cannot be resolved
> without any further changes. I'm not sure if this
> is an issue in Buckminster itself or is related to the installation on
> Hudson. Here are the links to the build logs:
> Michael
FUDForum. Page generated in 0.06578 seconds
