Home » Eclipse Projects » Eclipse 4 » Disallowing moving a part
Disallowing moving a part [message #663141] Sun, 03 April 2011 23:43 Go to next message
Hi all,
I would like to know what tag should be added to a part so that we disallow moving of the part? (dragging and dropping the part therby changing the perspective layout)
For disallowing closing it is "NoClose", but I can't seem to know for disallowing moving...
Thank you for your help!
Re: Disallowing moving a part [message #663317 is a reply to message #663141] Mon, 04 April 2011 11:13 Go to previous messageGo to next message
I've just committed the code to support this. The appropriate tag to use to inhibit moving a part is IPresentationEngine.NO_MOVE.
Adding this tag to a part will prevent the DnD's PartDragAgent from starting a drag on the part.
See bug 341793.
[Updated on: Mon, 04 April 2011 11:15] by Moderator
Re: Disallowing moving a part [message #663382 is a reply to message #663317] Mon, 04 April 2011 15:59 Go to previous messageGo to next message
This is not working Sad
part1.getTags().add("NoClose"); works!
part1.getTags().add("NoMove"); doesn'work!
part1.getTags().add(IPresentationEngine.NO_MOVE); doesn'work!
When I say doesn't work, it means I am still able to drag and drop a part to another place (say I can move it from the partstack it was in to another partstack, etc...)
This is the behavior I would like to disallow...
On the same topic, suppose the user moves around parts and changes perspective, is there a way to reset the perspective when the app starts again the next time?
Note that most of my application model is not programmatically defined, rather defined in the Application.e4xmi
Thank you
Re: Disallowing moving a part [message #663398 is a reply to message #663382] Mon, 04 April 2011 16:29 Go to previous messageGo to next message
Did you checked out the latest sources? As Eric said he just checked in
that change to CVS!
Tom
Am 04.04.11 21:59, schrieb AppleJus:
> This is not working :(
> Thank you
Re: Disallowing moving a part [message #663498 is a reply to message #663382] Tue, 05 April 2011 08:03 Go to previous messageGo to next message
AppleJus wrote on Mon, 04 April 2011 15:59
You need '-deltaRestore false' as an argument to your application.
If that's not working, use breakpoints in E4Application to check if it's being parsed correctly.
Re: Disallowing moving a part [message #663630 is a reply to message #663398] Tue, 05 April 2011 19:08 Go to previous messageGo to next message
Hi, thanks for your answers.
Sorry did not notice I should apply Eric's patch :/
But I am quite a newbie so I searched how to apply the bug fix patch but I am not able to know exactly how. Is it using the Team perspective in eclipse platform? But how to apply the patch to the e4 src code (not my project ).
Re: Disallowing moving a part [message #664245 is a reply to message #663317] Thu, 07 April 2011 22:23 Go to previous messageGo to next message
Hello Eric
Thank you for the contribution.
I downlaoed the latest I build (April 5, 2011)
and tried
part.getTags().add(IPresentationEngine.NO_MOVE);
but the tag still moves around..
NoClose works.
Re: Disallowing moving a part [message #664329 is a reply to message #664245] Fri, 08 April 2011 07:49 Go to previous message
On 04/07/2011 10:24 PM, AppleJus wrote:
> Hello Eric
> and tried
That build simply picked up the latest 3.7 I build as a base. His
changes should be in last night's build.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Part: closeable=false still creates closeable button in a PartSTack
Next Topic:Disabling a menu button not working
Current Time: Sun Jul 20 23:50:48 EDT 2025
Powered by FUDForum. Page generated in 0.03934 seconds
