Home » Modeling » OCL » Evaluate Ecore Instances programatically
Evaluate Ecore Instances programatically [message #663326] Mon, 04 April 2011 11:43 Go to next message
I am creating ECore model with OCL embedded in it programatically using JAVA. I am also creating instances of Ecore model but i want instances with evaluated values with respect to OCL derivations defined inside Ecore. As there are some attribute having derivation statement. I want to access those attributes and want to get the derived values from them.
class Library
property totalBooks : ecore_0::EDouble[1] { derived,volatile }
derivation: self.books.copies->sum() + testFunction1();
property books : Book[*] { composes };
property members : Member[*] { composes };
property loans : Loan[*] { composes };
operation testFunction1() : ecore_0::EInt[?]
body: 2;
class Book
attribute name : String[?];
attribute copies : ecore_0::EIntegerObject[?];
class Loan
property member : Member[1];
property book : Book[1];
This is structure of my generated Ecore. I am taking the instance of library and added few books into it and wants that Library.totalBooks should have calculated values.
Please guide me!
Warmest Regards,
Khurram
Re: Evaluate Ecore Instances programatically [message #663335 is a reply to message #663326] Mon, 04 April 2011 12:32 Go to previous message
Hi Khurram
Your example looks very like what the OCLinEcore editor will give you so
I'm presuming that is what you are using.
If you genmodel your model, the OCL text is persisted in the
EAnnotations, so that the OCL can be interpreted appropriately.
(Make sure you set the Operation Reflection parameter to true.)
Then if you're using plugins you need to do no more, the plugin
registrations will happen automatically.
If you are running Standalone you need to 'manually' register the OCL
delegate registrations:
The following is cut and paste from
org.eclipse.ocl.ecore.tests.DelegatesTest.java
String oclDelegateURI = OCLDelegateDomain.OCL_DELEGATE_URI;
if (!eclipseIsRunning) { // Install the 'plugin'
registrations
EOperation.Internal.InvocationDelegate.Factory.Registry.INST ANCE.put(oclDelegateURI,
new OCLInvocationDelegateFactory.Global());
EStructuralFeature.Internal.SettingDelegate.Factory.Registry .INSTANCE.put(oclDelegateURI,
new OCLSettingDelegateFactory.Global());
EValidator.ValidationDelegate.Registry.INSTANCE.put(oclDeleg ateURI,
new OCLValidationDelegateFactory.Global());
HTH
Ed Willink
On 04/04/2011 16:43, khurram wrote:
> class Library
> body: 2;
> class Book
> class Loan
> Please guide me!
> Warmest Regards,
> Khurram
Previous Topic:Annotated OCL in Ecore model not working in Helios
Next Topic:Re: model query
Current Time: Wed Jul 23 02:40:13 EDT 2025
Powered by FUDForum. Page generated in 0.56441 seconds
