Home » Eclipse Projects » Rich Client Platform (RCP) » Views placement in one perspective
Views placement in one perspective [message #663170] Mon, 04 April 2011 04:20 Go to next message
Hello
I have 3 views: V1, V2 and V3 and would like to place them as following:
| V1 | V2 |
| V3 |
I.e. V3 spans the whole bottom. I am currently doing following in "perspectiveExtension" of plugin.xml:
1. For V1: relationShip = left, relative = org.eclipse.ui.editorss.
2. For V2: relationShip = right, relative = org.eclipse.ui.editorss.
3. For V3: relationShip = bottom. But what should be the value of "relative" ? If I assign V1 or V2, it will be placed under the view I assigned...
Thank you,
Arkady.
Re: Views placement in one perspective [message #663171 is a reply to message #663170] Mon, 04 April 2011 04:23 Go to previous messageGo to next message
May be my picture is misleading, I meant V3 will take the whole bottom (not under V1 only).
Re: Views placement in one perspective [message #663242 is a reply to message #663170] Mon, 04 April 2011 08:21 Go to previous messageGo to next message
On 04/04/2011 04:20 AM, arkadyz wrote:
> Hello
> | V1 | V2 |
> | V3 |
> assigned...
you have to do something like place V1, place V3 under V1, then place V2
next to V1
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Views placement in one perspective [message #663247 is a reply to message #663242] Mon, 04 April 2011 08:56 Go to previous message
Paul,
You are the best !!! It succeeded, thank you.
Previous Topic:Eclipse and Java FX
Next Topic:Eclipse Presentation API: Customize L&F of minimized views
Current Time: Sat Jul 26 08:48:57 EDT 2025
Powered by FUDForum. Page generated in 0.03177 seconds
