Home » Eclipse Projects » Rich Client Platform (RCP) » Adapter pattern in eclipse: is it possible to have multiple adapter factories on platform?
Adapter pattern in eclipse: is it possible to have multiple adapter factories on platform? [message #663238] Mon, 04 April 2011 08:45 Go to next message
I would like to use an adapter pattern to present data model from the legacy part of Eclipse RCP application I'm working on.
But there is already adapter factory for the adaptable type and I can not change that code.
Is it possible to declare additional adapter factory for the adaptable type on the Platform to make an adapter that is not present in the core (legacy) system? Or someone recommends some other approach as better solution.
Thanks in advance!
P.S. Tutorial: http://www.jeffreyricker.com/papers/Eclipse-Adapters.pdf
[Updated on: Mon, 04 April 2011 08:50] by Moderator
Re: Adapter pattern in ecluipse: is it possible to have multiple adapter factories on platform? [message #663272 is a reply to message #663238] Mon, 04 April 2011 09:45 Go to previous messageGo to next message
As I understand it, an adapter factory is keyed on a the tuple of
sourceType,targetType. So if you were contributing a new source data
model, you could still provide an adapter factory that turned it into an
IFile representation, for example.
Or do you mean there's already a (sourceType, targetType) factory
declaration?
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Adapter pattern in ecluipse: is it possible to have multiple adapter factories on platform? [message #663280 is a reply to message #663272] Mon, 04 April 2011 10:09 Go to previous messageGo to next message
Actually I have core plugin, product platform that I can not change. But I'm using its data model. Some domain data about logging and test results.
The core system has its adapter factory which it uses for the data presentation in some tree viewer.
Now in my plugin I'm using the same data from the core plugin and I have to attach some additional informations to each data model element.
If it would be possible to change source from the core plugin, I would just add (and implement) my new adapter to existing adapter factory.
But as I can not do that I wonder if I can register in my plugin another adapter factory but for the cores domain type and convert it to my object.
Core plugin: domain type - adaptable object, object with which we are starting - source type.
Core plugin: adapter factory used for cores presentation layer.
My plugin: adapter type - my new object to which I want to adapt. New targetType, which is is not part of the existing adapter factory.
Since I can not add new targetType to existing adapter factory it would be convenient for me, if It is allowed to register additional adapter factory fort the adaptable type that already has one adapter factory. Or I need to find some workaround for that.
Tihomir
[Updated on: Mon, 04 April 2011 10:26] by Moderator
Re: Adapter pattern in ecluipse: is it possible to have multiple adapter factories on platform? [message #663287 is a reply to message #663280] Mon, 04 April 2011 10:26 Go to previous messageGo to next message
On 04/04/2011 10:09 AM, Tihomir wrote:
> Therefore it would be convenient for me, if It is allowed to register
> adapter factory.
Well, did it pass the test from my other post? If there is already
(yourType, corePresentationType) adapter factory provided then it won't
work properly.
PW
Paul Webster
Re: Adapter pattern in ecluipse: is it possible to have multiple adapter factories on platform? [message #663294 is a reply to message #663287] Mon, 04 April 2011 10:51 Go to previous messageGo to next message
Thx, for replying.
But due to some deadlines maybe I'll not be able to make an test before tomorrow.
At the moment the core has (coreSrcType, coreTargetType) factory.
And I would need to have (coreSrcType, myTargetType) factory. So I'm not quite sure if I'm allowed to simply add an new (additional) factory for that coreSrcType (adaptableType).
Tihomir
Re: Adapter pattern in ecluipse: is it possible to have multiple adapter factories on platform? [message #663357 is a reply to message #663294] Mon, 04 April 2011 14:41 Go to previous messageGo to next message
On 04/04/2011 10:51 AM, Tihomir wrote:
> Thx, for replying.
> tomorrow.
You are basically stating that you are creating a new system (processing
or presentation), and you need to adapt the core datamodel to
MyTargetType which your new system understands. That is definitely allowed.
PW
Paul Webster
Re: Adapter pattern in eclipse: is it possible to have multiple adapter factories on platform? [message #663834 is a reply to message #663357] Wed, 06 April 2011 11:21 Go to previous message
Thx, again!
Paul, you have right, it is allowed to register and use new Adapter Factory.
I still has some problems with presenting combination of core system data model and new system data model in tree viewer - stack overflow exception occurs. But it is clear that using Adapter Mechanism is reasonable approach for my case.
Previous Topic:how to define activeWhen for Undo/Redo handlers
Next Topic:How to hide the Editor tab
Current Time: Sat Jul 26 07:53:51 EDT 2025
Powered by FUDForum. Page generated in 0.08639 seconds
