Home » Eclipse Projects » EGit / JGit » Using EGit with Assembla.com(Push to Another Repository dialog won't accept colon, subsitutes forward slash)
Using EGit with Assembla.com [message #663143] Mon, 04 April 2011 00:30 Go to next message
EGit newbe here trying to get repositories set up with Assembla.com.
Assembla says this is the URL for my repository:
git@git.assembla.com:cprsfg_test_common.git
I am attempting to push the git repository. The Push To Another Repository dialog change the URL to:
git@git.assembla.com/cprsfg_test_common.git
The dialog replaces the colon after the host with a forward slash.
Is this ok? Will either URL work?
EGit version 0.11.3 would let me put the colon back if I fiddled with the dialong enough.
EGit version 0.12.201104031836 will not let me put a colon in the URI
What does the colon in the URL which Assembla publishes mean?
Bill Blalock
Re: Using EGit with Assembla.com [message #663147 is a reply to message #663143] Mon, 04 April 2011 01:42 Go to previous message
The colon just separates the hostname from the path. The Git URLs are mentioned in the git clone documentation
I assume assembla uses ssh, so you could use:
ssh://git@git.assembla.com/cprsfg_test_common.git
git@git.assembla.com:/cprsfg_test_common.git
Edit:
Somehow this form hates git@ so the above should have that.
[Updated on: Mon, 04 April 2011 01:46] by Moderator
Previous Topic:Newbie q re: installing egit
Next Topic:How to limit the amount of history which is shown?
Current Time: Fri Jul 18 20:09:30 EDT 2025
Powered by FUDForum. Page generated in 0.04416 seconds
