Home » Modeling » EMF » Generated tests from EMF
Generated tests from EMF [message #662581] |
Thu, 31 March 2011 04:35  |
We can generated unit tests for our EMF model. When i look at these tests most of them are empty blocks.
What is the real purpose of these tests ?
Have someone used these generated tests ? Can you share your experience by this feature ?
Ashwani Kr Sharma
Re: Generated tests from EMF [message #663060 is a reply to message #662703] |
Sat, 02 April 2011 17:32   |
Ed,
Why is then that all generated test end up with:
// TODO: implement this operation test method
// Ensure that you remove @generated or mark it @generated NOT
fail();
which by default causes hundreds of failures. What we would want is the
for the default to do nothing, just put a TODO and we can implement only
the tests we care about and still get the scaffolding generated.
Or am I missing something obvious?
Alain
On 3/31/2011 11:43 AM, Ed Merks wrote:
> Ashwani,
> Comments below.
> Ashwani Kr Sharma wrote:
>> Hi,
> They're scaffolding in which you can write meaningful tests.
> The UML2 project has used them. So you might look at their source.
> Think about it though... If you have a well formed model, EMF always
> generated a correct implementation of it. There's really nothing to
> test. If there were tests that failed, we'd have to fix the generator so
> they didn't. The only things that need testing is the code that you add
> yourself to the generated classes. As you add such code, you should
> write the tests to validate and confirm correct expected behavior.
>> Regards,
>> Ashwani Kr Sharma
Re: Generated tests from EMF [message #663061 is a reply to message #663060] |
Sat, 02 April 2011 19:19   |
Alain,
Presumably all operations do something meaningful/useful that's worth
testing. That's the assumption we're making...
Alain Picard wrote:
> Ed,
> fail();
> the for the default to do nothing, just put a TODO and we can
> implement only the tests we care about and still get the scaffolding
> generated.
> Cheers,
> Alain
>> Ashwani,
>> Comments below.
>>> Hi,
>>> Regards,
>>> Ashwani Kr Sharma
Re: Generated tests from EMF [message #663093 is a reply to message #663061] |
Sun, 03 April 2011 10:20   |
Why not just like the unimplemented method, throw a
NotImplementedException(), the difference would be clearer.
Alain
On 4/2/2011 7:19 PM, Ed Merks wrote:
> Alain,
> Alain Picard wrote:
>> Ed,
>> fail();
>> generated.
>> Cheers,
>> Alain
>>> Ashwani,
>>> Comments below.
>>>> Hi,
>>>> Regards,
>>>> Ashwani Kr Sharma
Re: Generated tests from EMF [message #663094 is a reply to message #663093] |
Sun, 03 April 2011 10:24   |
Sorry, meant: UnsupportedOperationException()
Alain
> Alain
>> Alain,
>> Alain Picard wrote:
>>> Ed,
>>> fail();
>>> generated.
>>> Cheers,
>>> Alain
>>>> Ashwani,
>>>> Comments below.
>>>>> Hi,
>>>> generator so
>>>>> Regards,
>>>>> Ashwani Kr Sharma
Re: Generated tests from EMF [message #663105 is a reply to message #663093] |
Sun, 03 April 2011 12:36   |
Alain,
Wouldn't that just produce a different kind of failure? It's not
obvious to me why that kind of failure would be better or more clear.
Certainly a TODO automatically produces markers that are designed to
call attention to things that need to be done...
> Alain
>> Alain,
>> Alain Picard wrote:
>>> Ed,
>>> fail();
>>> generated.
>>> Cheers,
>>> Alain
>>>> Ashwani,
>>>> Comments below.
>>>>> Hi,
>>>> generator so
>>>> add
>>>>> Regards,
>>>>> Ashwani Kr Sharma
Re: Generated tests from EMF [message #663135 is a reply to message #663105] |
Sun, 03 April 2011 20:03  |
IMHO it would make it a bit easier to discern what is a test failure vs.
a non implementation.
Alain
On 4/3/2011 12:36 PM, Ed Merks wrote:
> Alain,
> Wouldn't that just produce a different kind of failure? It's not obvious
> to me why that kind of failure would be better or more clear. Certainly
> a TODO automatically produces markers that are designed to call
>> Alain
>>> Alain,
>>> Alain Picard wrote:
>>>> Ed,
>>>> fail();
>>>> generated.
>>>> Cheers,
>>>> Alain
>>>>> Ashwani,
>>>>> Comments below.
>>>>>> Hi,
>>>>> generator so
>>>>> add
>>>>>> Regards,
>>>>>> Ashwani Kr Sharma
Current Time: Sun Jul 27 09:04:43 EDT 2025
Powered by FUDForum. Page generated in 0.32842 seconds
