Automatically add comment [message #662751] |
Thu, 31 March 2011 15:09  |
I tried to install doxygen (which has been done successfully), and then I searched for a function to automatically generate the parameters in doxygen format.
I searched the web and found the feature "automatically generate comment", but without effect (and without any documentation how to use it)
Is this feature implemented ind CDT ?
Is there any documentation of the usage ?
I tried to change the code templates, but was not successful.
I'm using code sourcery and helios in the newest version.
Thanks in advance
Dirk
Re: Automatically add comment [message #995075 is a reply to message #662751] |
Fri, 28 December 2012 21:08  |
Eclipse CDT is a C/C++ development IDE based on Eclipse (which defaults to Java development).
CodeSourcery Lite is GCC-based ARM toolchain which provides all the basic ingredients (compiler, assembler, archiver, linker, libraries, newlib, binutils, etc.) in console based executables. The best thing about CodeSourcery is that they also offer commercial solutions which result in quarterly updates to the Lite tool-chain also. This way you always stay inline with the latest GCC developments.
First let's have a look at the pre-requisites. You will need the latest version of Apple Developer Tools which include Xcode, Interface Designer, Instruments etc. and can be download from the Mac App Store. It is needed for the initial building of the toolchain which requires gcc, binutils and make. If you do not want to install the Developer Tools package, you will have to download and install these components individually. Google will help you.
Let's start now.
Step 1 Install Eclipse
Download and install the Eclipse IDE from http://www.eclipse.org. Eclipse Helios. The download page would provide you with a variety of flavors for the IDE. All of them are useful sometime or the other and can be ported to different versions using plugins. So go for the "Eclipse IDE for C/C++ Developers". It would have all the functionality needed to set up the toolchain.
Step 2 Install Eclipse Plugins Fueling up Eclipse
This step involves adding the necessary plugins to Eclipse which are needed to successfully compile an ARM application.
Eclipse CDT
Go to Help > Install New Software.
In the dialog which appears, type "http://download.eclipse.org/tools/cdt/releases/helios" in the Work With text area.
Press enter.
You will get a window as shown below. Select both the choices and click on Next. Accept the license agreement and continue with the installation.
Once the installation is complete, restart Eclipse.
FUDForum. Page generated in 0.04082 seconds
