Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF](xml file to emf model)
[EMF] [message #662427] Wed, 30 March 2011 11:44 Go to next message
I have a XML file contains my model that is not an EMF model.
I want to change it to an EMF model.
knowing that I generate the metate-model EMF corresponding from the XSD.
So is it possible to transform a file XML to an EMF model?
Re: [EMF] [message #662450 is a reply to message #662427] Wed, 30 March 2011 13:07 Go to previous messageGo to next message
Yes, of course that's possible. There are several articles on the
documentation page that show how it's done as well as a full tutorial
for how to create a model from an XML Schema. In fact, if you invoke
"Generate Test Code", in the *.tests project there will be a
XyzExample.java that shows how to do the loading and saving of the XML
in a standalone code snippet.
Re: [EMF] [message #662718 is a reply to message #662450] Thu, 31 March 2011 12:13 Go to previous messageGo to next message
thnak you for your reply,
I don't found the right way to do that, can you tell me exactly haw can I a load a xml file to have emf model?
EMF provide the feature of jaxb (Unmarshaller)??
Re: [EMF] [message #662727 is a reply to message #662718] Thu, 31 March 2011 12:30 Go to previous messageGo to next message
Which articles have you read and which tutorials have you followed?
Re: [EMF] [message #662846 is a reply to message #662727] Fri, 01 April 2011 04:33 Go to previous messageGo to next message
I tried to use the method in the class XyzExample.java but I have not succeeded.
can you tell me which tutorials I follow.
Re: [EMF] [message #662977 is a reply to message #662846] Fri, 01 April 2011 11:54 Go to previous messageGo to next message
--------------050506040106040505050807
Tutorial: Generating an EMF Model using XML Schema
< http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html>
> succeeded.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
<a
href=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html">Tutorial:
Generating an EMF Model using XML Schema</a><br>
<br>
ST wrote:
<blockquote cite="mid:in4281$drv$1@news.eclipse.org" type="cite"><br>
<br>
succeeded.
<br>
<br>
</blockquote>
</body>
</html>
--------------050506040106040505050807--
Re: [EMF] [message #663176 is a reply to message #662977] Mon, 04 April 2011 04:54 Go to previous messageGo to next message
Thank you any way,
I was sure that you do not understand me, I Created the metat-model from XSD.
and now I want PARSS xml file to create an instance of the model.
in other words I want to extract the information from xml file to fill in the model.
Re: [EMF] [message #663321 is a reply to message #663176] Mon, 04 April 2011 11:17 Go to previous message
Stéphane,
Have you managed to invoke Generate Test Code to actually look at the
generated XyzExample.java? You said something vague about not
succeeding to use it. You might want to spare a few words elaborating
on that...
stéphane wrote:
> Thank you any way,
> from XSD.
> in the model.
Previous Topic:[emf compare]
Next Topic:[EEF] Master detail form extension
Current Time: Sat Jul 26 12:06:45 EDT 2025
Powered by FUDForum. Page generated in 0.05610 seconds
