Home » Archived » BIRT » How to decode column value ?
How to decode column value ? [message #662559] Thu, 31 March 2011 02:40 Go to next message
Hi Forum,,
I'm new in birt and mауbe this is a trivial question but I can't find the answer.
So, I have Data Set like this:
SELECT col1, col2 , col3
FROM myTable.
where col1, col2 , col3 are integers and with join with another tables this values must be decoded to see the text.
I know two way to approach the task:
1. to create many joins in select
2. to create many birt Joint Data Sets - this is a foolish decision=
So is there some way to do this dynamically? Something like MAP but using Data Set
Re: How to decode column value ? [message #662699 is a reply to message #662559] Thu, 31 March 2011 11:34 Go to previous message
I am not certain I understand what you need, but if its a map why not
use the map on the table or report item that displays the data? You
could also create a computed column on the dataset that checks the value
of another column and returns a value based on it.
Jason
On 3/31/2011 2:40 AM, KrasiG wrote:
> Hi Forum,,
> the answer.
> FROM myTable.
> using Data Set
Previous Topic:Report Problem
Next Topic:Transform table
Current Time: Thu Jul 24 22:30:48 EDT 2025
Powered by FUDForum. Page generated in 0.02334 seconds
