| config.ini - osgi.splashPath [message #662297] |
Wed, 30 March 2011 03:37  |
I build an RCP application with Tycho. I originally use Tycho 1.10.0, and the eclipse-application packaging.
All is working well... except the splash screen which is not shown. The issue is that the osgi.splashPath property in the config.ini generated by tycho is incorrect !
It is :
osgi.splashPath=platform\:/base/plugins/com
Instead of :
osgi.splashPath=platform\:/base/plugins/com.my.plugin
It seams to be a known bug, as a 'split' is done on the first dot instead of the last one.
However, I've tried to use Tycho 1.11.0 but this doesn't correct this issue !
Thus, what can I do ? Is the packaging eclipse-application deprecated ? I've found some topics about the eclipse-repository packaging, but I'm not sure that it corresponds to my need. Any info ?
FUDForum. Page generated in 0.03758 seconds
