Having trouble with WindowBuilder Jface binding using a combo [message #662258] |
Tue, 29 March 2011 18:14  |
Hi all,
I'm new to Eclipse RCP and Windowbuilder and i'm having some trouble wrapping my head around the binding interface of Windowbuilder.
My goal is to populate a combo with a list of services. These services are contained in a model which also tracks the active service.
Essentially, the model looks like this:
class SourceModel
List<ServiceX> services;
ServiceX currentService;
interface ServiceX
getName() <--what I wish to see in the combo list
plus various interface methods
I have a View with a combo widget and I would like to populate this with the services list in the model. I have have achieved this with the binding designed in WindowBuilder. The input is bound to the services list using the getName() as the label provider.
Where I am stumped is using the currentService field to set the currently selected option in the combo. currentService is set in the constructor of the SourceModel so the combo should display that ServiceX as the selected.
Hopefully this makes sense.
Thanks in advance for any help.
[Updated on: Wed, 30 March 2011 02:18] by Moderator
Re: Having trouble with WindowBuilder Jface binding using a combo [message #664279 is a reply to message #662258] |
Fri, 08 April 2011 04:58   |
You cant use Combo for this. Use JFace ComboViewer:
package com.instantiations.designer.test.rcp.databindings;
import java.util.ArrayList;
import java.util.List;
import org.eclipse.core.databinding.DataBindingContext;
import org.eclipse.core.databinding.beans.PojoObservables;
import org.eclipse.core.databinding.observable.Realm;
import org.eclipse.core.databinding.observable.list.WritableList;
import org.eclipse.core.databinding.observable.map.IObservableMap;
import org.eclipse.core.databinding.observable.value.IObservableValue;
import org.eclipse.jface.databinding.swt.SWTObservables;
import org.eclipse.jface.databinding.viewers.ObservableListContentProvider;
import org.eclipse.jface.databinding.viewers.ObservableMapLabelProvider;
import org.eclipse.jface.databinding.viewers.ViewersObservables;
import org.eclipse.jface.viewers.ComboViewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Combo;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
public class App_Combo_test {
private DataBindingContext m_bindingContext;
public static interface ServiceX {
public String getName();
private ServiceX currentService;
public class Self {
public ServiceX getCurrentService() {
return currentService;
public void setCurrentService(ServiceX currentService) {
App_Combo_test.this.currentService = currentService;
Self self = new Self();
protected Shell shell;
private ComboViewer comboViewer;
* Launch the application.
* @param args
Display display = Display.getDefault();
Realm.runWithDefault(SWTObservables.getRealm(display), new Runnable() {
public void run() {
try {
App_Combo_test window = new App_Combo_test();
window.open();
} catch (Exception e) {
e.printStackTrace();
* Open the window.
public void open() {
createContents();
shell.open();
shell.layout();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
* Create contents of the window.
protected void createContents() {
shell = new Shell();
shell.setSize(450, 300);
shell.setText("SWT Application");
Label label = new Label(shell, SWT.NONE);
label.setBounds(10, 10, 269, 17);
label.setText("Combo databinding test");
comboViewer = new ComboViewer(shell, SWT.NONE);
Combo combo = comboViewer.getCombo();
combo.setBounds(10, 33, 185, 27);
ServiceX service1 = new ServiceX() {
public String getName() {
return "service1";
ServiceX service2 = new ServiceX() {
return "service2";
ServiceX service3 = new ServiceX() {
return "service3";
services = new ArrayList<ServiceX>();
services.add(service1);
services.add(service2);
services.add(service3);
self.setCurrentService(service2);
m_bindingContext = initDataBindings();
protected DataBindingContext initDataBindings() {
DataBindingContext bindingContext = new DataBindingContext();
ObservableListContentProvider listContentProvider = new ObservableListContentProvider();
comboViewer.setContentProvider(listContentProvider);
IObservableMap observeMap = PojoObservables.observeMap(
listContentProvider.getKnownElements(), ServiceX.class, "name");
comboViewer
.setLabelProvider(new ObservableMapLabelProvider(observeMap));
WritableList writableList = new WritableList(services, ServiceX.class);
comboViewer.setInput(writableList);
IObservableValue comboViewerObserveSingleSelection = ViewersObservables
.observeSingleSelection(comboViewer);
IObservableValue selfCurrentServiceObserveValue = PojoObservables
.observeValue(self, "currentService");
bindingContext.bindValue(comboViewerObserveSingleSelection,
selfCurrentServiceObserveValue, null, null);
return bindingContext;
FUDForum. Page generated in 0.07869 seconds
