Home » Modeling » Graphiti » Images from user directories (as opposed to plugin resources)(How to create an Image from a file in the diagram users directory?)
Images from user directories (as opposed to plugin resources) [message #661882] Mon, 28 March 2011 08:11 Go to next message
I want to include in my diagrams images from the users directory, i.e. not from
the plugin. I tried using a second ImageProvider, but I cannot get this to work
for images from sources different than the plugin directory space. Using mutiple ImageProviders for images from the plugin works fine (once the Imageprovides are both declared (twice) in the plugin.xml file.
My first ImageProvider works fine and provides the icons necessary for the
diagram type (e.g. for the ContextButtons).
How to construct an ImageProvider which looks for images in the users
directory?
Or do I have to replicate a lot of code and provide my own Graphics Algorithm?
[Updated on: Mon, 28 March 2011 08:39] by Moderator
Re: Images from user directories (as opposed to plugin resources) [message #662235 is a reply to message #661882] Tue, 29 March 2011 15:44 Go to previous messageGo to next message
After many experiments, I solved my problem myself: To make my ImageProvider work with local files, I had to use file.getLocationURI().toString() instead of file.file.getFullPath().toString().
Re: Images from user directories (as opposed to plugin resources) [message #663260 is a reply to message #661882] Mon, 04 April 2011 09:07 Go to previous messageGo to next message
1. seems still to be open:
You can register several ImageProviders simply by adding them to the
defeinition of your DiagramTypeProvider in your plugin.xml
Michael
"J. Weimar" wrote in message news:imptgq$qm8$1@news.eclipse.org...
from
work
even for images from the plugin directory space.
Therefore I now have two problems:
1. Is it possible to use more than one ImageProvider? The code seems to go
through a list, but I cannot get more than one ImageProvider to work.
2. How to construct an ImageProvider which looks for images in the users
directory?
Re: Images from user directories (as opposed to plugin resources) [message #663292 is a reply to message #663260] Mon, 04 April 2011 10:44 Go to previous message
Thanks for the reply, I edited the original request to remove 1. once I solved the problem 1 myself. But your email copy did not get changed Sad.
Best regards, Jörg.
Previous Topic:Modifying a separate Ecore file outside Create-Features
Next Topic:Non Rectangular selection area
Current Time: Fri Jul 25 21:43:25 EDT 2025
Powered by FUDForum. Page generated in 0.05448 seconds
