Home » Eclipse Projects » Virgo » [Resolved] Redirect Virgo's Tomcat logs into console(I'm looking for the right configuration to redirect tomact logs to console)
icon14.gif  [Resolved] Redirect Virgo's Tomcat logs into console [message #662210] Tue, 29 March 2011 14:14 Go to next message
I integrated Virgo web server into Eclipse, but the problem is that tomcat logs are puten in a log file
is there a way to redirect it to Virgo's console on Eclipse ?
Thank you for help
[Updated on: Wed, 30 March 2011 11:42] by Moderator
Re: Redirect Virgo's Tomcat logs into console [message #662224 is a reply to message #662210] Tue, 29 March 2011 14:38 Go to previous messageGo to next message
Take a look in $VIRGO_HOME/config/serviceability.xml
This is a standard logback configuration file. Modify by adding more appenders and rout as needed
Dmitry
Re: Redirect Virgo's Tomcat logs into console [message #662321 is a reply to message #662224] Wed, 30 March 2011 05:08 Go to previous messageGo to next message
thank you for your reply
I opened the mentioned file, but i realize that i'm a newbie and cant figure out witch instructions to add to get the desired result
Re: Redirect Virgo's Tomcat logs into console [message #662336 is a reply to message #662224] Wed, 30 March 2011 05:41 Go to previous messageGo to next message
i added the following lines to the xml file :
<appender name="SIFTED_LOG_STDOUT" class="ch.qos.logback.classic.sift.SiftingAppender">
		<discriminator>
			<Key>applicationName</Key>
			<DefaultValue>virgo-server</DefaultValue>
		</discriminator>
		<sift>
			<appender name="${applicationName}_LOG_STDOUT" class="org.eclipse.virgo.medic.log.logback.ReroutingAwareConsoleAppender">
				<encoder class="ch.qos.logback.classic.encoder.PatternLayoutEncoder">
					<Pattern>[%d{yyyy-MM-dd HH:mm:ss.SSS}] %-28.28thread %-64.64logger{64} %X{medic.eventCode} %msg %ex%n</Pattern>
				</encoder>
			</appender>
		</sift>
	</appender>
So now i'm getting all applications logs on console, is there a way to put filter to get just tomcat's logs ?
Re: Redirect Virgo's Tomcat logs into console [message #662390 is a reply to message #662336] Wed, 30 March 2011 09:51 Go to previous messageGo to next message
Which "tomcat" logs are looking at?
Do you want to see logs of the application deployed in tomcat?
Do you want to see actual log statements generated by tomcat code base?
Do you want to see access logs for http requests served by tomcat?
Take a look here for logback documentation => http://logback.qos.ch/manual/index.html
In addition to the appender you will need a <logger/> element.
In logger element you can specify package (i.e. name) attribute) and an appender to use for that package.
Dmitry
Re: Redirect Virgo's Tomcat logs into console [message #662425 is a reply to message #662390] Wed, 30 March 2011 11:40 Go to previous message
thank you very much, your instructions were very useful to me,
i also noticed that there is an option in Virgo's panel:
http://img4.hostingpics.net/pics/120882Capture.png
thank you Mr Dmitry Sklyut
Previous Topic:LogReaderService for Virgo
Next Topic:[NOT POSSIBLE ] Change Embedded Tomcat
Current Time: Sun Aug 31 09:29:54 EDT 2025
Powered by FUDForum. Page generated in 0.04091 seconds
