[CDO] recover from lost connection [message #660464] |
Fri, 18 March 2011 10:15  |
I am investigating how CDO can handle instable connections. For this, I
wrote a small test which starts a TCP proxy. The CDO connection is
routed through this proxy. Stopping the proxy simulates a lost connection.
LOGGER.debug("starting proxy");
startProxy();
LOGGER.debug("creating session");
final CDOSession session = createSession(TCP_PROXY_URI);
try {
LOGGER.debug("stopping proxy (simulate disconnect)");
stopProxy();
Thread.sleep(1000);
LOGGER.debug("restarting proxy (simulate reconnect)");
startProxy();
LOGGER.debug("reactivate session (recover from lost connection)");
LifecycleUtil.activate(session);
LOGGER.debug("refreshing object caches");
session.refresh();
finally {
session.close();
stopProxy();
However, trying to reactivate the sessin fails with
org.eclipse.net4j.channel.ChannelException: java.lang.NullPointerException
at
org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(Channel Multiplexer.java:171)
at
org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(Channel Multiplexer.java:1)
at
org.eclipse.net4j.signal.failover.NOOPFailOverStrategy.handl eOpen(NOOPFailOverStrategy.java:53)
at org.eclipse.net4j.signal.SignalProtocol.open(SignalProtocol. java:169)
at
org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtoco l.openSession(CDOClientProtocol.java:91)
at
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionConfigurat ionImpl.activateSession(CDONet4jSessionConfigurationImpl.jav a:216)
at
org.eclipse.emf.internal.cdo.session.CDOSessionImpl.doActiva te(CDOSessionImpl.java:999)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycl e.java:72)
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:98)
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:88)
When skipping the reactivation, any operation on the session quits with
the error
java.lang.IllegalStateException: Not active: CDOSession[cmtmem, 77]
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.checkActive(L ifecycleUtil.java:71)
at
org.eclipse.net4j.util.lifecycle.Lifecycle.checkActive(Lifec ycle.java:190)
at
org.eclipse.emf.internal.cdo.session.CDOSessionImpl.refresh( CDOSessionImpl.java:505)
So what is the correct way to handle this? Is it possible to have this
done automagically?
Sebastian Paul
Re: [CDO] recover from lost connection [message #660489 is a reply to message #660464] |
Fri, 18 March 2011 11:46   |
Sebastian,
please take a look at ReconnectingCDOSessionConfiguration.
org.eclipse.emf.cdo.net4j.ReconnectingCDOSessionConfiguratio n
org.eclipse.emf.cdo.net4j.CDONet4jUtil.createReconnectingSes sionConfiguration(String,
String, IManagedContainer)
Haven't tried it, but seems what your looking for ;)
Víctor.
Sebastian Paul escribió:
> startProxy();
> try {
> stopProxy();
> Thread.sleep(1000);
> startProxy();
> session.refresh();
> finally {
> session.close();
> stopProxy();
> at
> at
> at
> at
> at
> at
> at
> at
> the error
> at
> at
> at
> done automagically?
Re: [CDO] recover from lost connection [message #662100 is a reply to message #660535] |
Tue, 29 March 2011 05:55   |
now I have got the time for testing this with CDO 4.0, with partial success:
public void testConnectionLostWithRecovery() throws Exception {
final CDOSession session = createReconnectingSession();
try {
tcpProxy.stop();
tcpProxy.start();
session.refresh();
finally {
session.close();
public void testTransactionWithLostConnectionAndRecovery() throws
Exception {
try {
LOGGER.debug("opening transaction");
final CDOTransaction transaction = session.openTransaction();
LOGGER.debug("modifying resource");
final CDOResource resource =
transaction.getOrCreateResource(CDO_RESOURCE_PATH);
resource.getContents().add(createContent());
tcpProxy.stop();
tcpProxy.start();
LOGGER.debug("committing transaction");
transaction.commit();
finally {
session.close();
private CDOSession createReconnectingSession() {
final String hostAndPort = TCP_PROXY_URI.getHost() + ':' +
TCP_PROXY_URI.getPort();
final Path path = new Path(TCP_PROXY_URI.getPath());
final String repoName = path.segment(0);
final IManagedContainer container =
org.eclipse.net4j.internal.util.container.PluginContainer.ge tInstance();
final CDOSessionConfiguration sessionConfiguration =
CDONet4jUtil.createReconnectingSessionConfiguration(hostAndP ort,
repoName, container);
final CDOSession session = sessionConfiguration.openSession();
return session;
The test "testConnectionLostWithRecovery" succeeds.
But the test "testTransactionWithLostConnectionAndRecovery" fails:
org.eclipse.emf.cdo.util.CommitException: java.lang.NullPointerException
at
org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl. commit(CDOTransactionImpl.java:1067)
at
org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl. commit(CDOTransactionImpl.java:1073)
at ITCdoConnection.testTransactionWithLostConnectionAndRecovery
Maybe my session configuration is wrong?
I am wondering about the IManagedContainer which I have to provide to
CDONet4jUtil#createReconnectingSessionConfiguration. Currently I am
accessing internal API. What is the correct way to get an instance?
Am 2011-03-18 23:52, schrieb Eike Stepper:
> Hi Sebastian,
> I recall someone else has tried to backport our respective code from
> 4.0. And failed :P
> It's not a trivial undertaking and I think you'd be better served with
> CDO 4.0.
> Cheers
> /Eike
> http://www.esc-net.de
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
> Am 18.03.2011 17:22, schrieb Sebastian Paul:
>> Am 2011-03-18 16:46, schrieb Víctor Roldán Betancort:
>> Hi, thanks for the hint. I forgot to mention that I am using the
>> latest stable release of CDO, which is 3.0.1. As I cannot find the
>> type in my workspace, I guess it will be introduced in CDO 4.0.
>> So I have to change my question and ask "How can I recover from a lost
>> connection in CDO 3.x" ;)
>> Kind regards, Sebastian
Sebastian Paul
FUDForum. Page generated in 0.04900 seconds
