Home » Archived » BIRT » [HELP]Problems when rendering in HTML through JavaBridge (URGENT )
[HELP]Problems when rendering in HTML through JavaBridge [message #662150] Tue, 29 March 2011 10:23 Go to next message
Hello all,
Im getting an exception when rendering the report throught PHP using JavaBridge. I got Birt version 2.5.2 both Runtime and RCP, JavaBridge 6.1, PHP 5.3, Tomcat 6.0.18. I tried following the thread http://www.eclipse.org/forums/index.php?t=tree&goto=6300 15&S=04e3e2c8cfb972f74f613b959d5986a7
but all this thread discuss is about how getting the log errors, it didnt solved any of my problems. Please i need this urgent someone help.
Obs.: Im testing a report with only 1 data set it works fine in BIRt preview, web viewer and all other formats but in PHP the only format i cant export is the HTML until PDF is working fine in it.
Error:
Error generating HTML [[o:Exception]:"java.lang.Exception: Invoke failed: [[o:RunAndRenderTask]]->run. Cause: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report VM: 1.6.0_23@http://java.sun.com/" at: #-11 org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:188) #-10 org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:75) #-9 sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) #-8 sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) #-7 sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) #-6 java.lang.reflect.Method.invoke(Unknown Source) #-5 php.java.bridge.JavaBridge.Invoke(JavaBridge.java:1044) #-4 php.java.bridge.Request.handleRequest(Request.java:417) #-3 php.java.bridge.Request.handleRequests(Request.java:500) #-2 php.java.bridge.http.ContextRunner.run(ContextRunner.java:14 5) #-1 php.java.bridge.ThreadPool$Delegate.run(ThreadPool.java:60) #0 http://localhost:9191/JavaBridge/java/Java.inc(232): java_ThrowExceptionProxyFactory->getProxy(54, '@V', 'T', true) #1 http://localhost:9191/JavaBridge/java/Java.inc(360): java_Arg->getResult(true) #2 http://localhost:9191/JavaBridge/java/Java.inc(366): java_Client->getWrappedResult(true) #3 http://localhost:9191/JavaBridge/java/Java.inc(560): java_Client->getResult() #4 http://localhost:9191/JavaBridge/java/Java.inc(1752): java_Client->invokeMethod(7, 'run', Array) #5 http://localhost:9191/JavaBridge/java/Java.inc(1851): java_JavaProxy->__call('run', Array) #6 http://localhost:9191/JavaBridge/java/Java.inc(1999): java_AbstractJava->__call('run', Array) #7 C:\workfolder\gustavoviana\setforms\v_100\p4a\objects\birt.p hp(196): Java->__call('run', Array) #8 C:\workfolder\gustavoviana\setforms\v_100\p4a\objects\birt.p hp(196): java_InternalJava->run() #9 C:\workfolder\gustavoviana\products\v_100\classes\geral\faca de\TkBirtReport.php(46): Birt->getHTML() #10 C:\workfolder\gustavoviana\products\v_100\reports\birt\birt_ report.php(37): TkBirtReport->getHTML() #11 C:\workfolder\gustavoviana\products\v_100\source\ron\Debugge r.php(19): require_once('C:\workfolder\g...') #12 {main}]
Re: [HELP]Problems when rendering in HTML through JavaBridge [message #662191 is a reply to message #662150] Tue, 29 March 2011 12:22 Go to previous messageGo to next message
I replied to your post on Birt Exchange. Take a look at :
http://www.birt-exchange.org/org/devshare/deploying-birt-rep orts/1309-javabridge-configuration-tutorial/
Jason
On 3/29/2011 10:23 AM, Gustavo wrote:
> Hello all,
> Error:
> java_ThrowExceptionProxyFactory->getProxy(54, mailto:'@V', 'T', true) #1
Re: [HELP]Problems when rendering in HTML through JavaBridge [message #662236 is a reply to message #662150] Tue, 29 March 2011 15:54 Go to previous message
jason im posting my reply here since birt exchange forum seems to be offline.
Ok i teste all .php examples files from the JavaBridge folder separetly.
One of them is generating this error.:
the file: PhpRunAndRenderHTMLDrillDetail.php
[[o:Exception]:"java.lang.Exception: Invoke failed: [[o:ReportEngine]]->openReportDesign((o:String)[o:String]). Cause: org.eclipse.birt.report.engine.api.EngineException: The design file false can not be found. VM: 1.6.0_23@http://java.sun.com/" at: #-10
[Updated on: Tue, 29 March 2011 15:56] by Moderator
Previous Topic:Image won't be stored in directory specified
Next Topic:Database access in Servlet
Current Time: Sat Jul 26 18:46:00 EDT 2025
Powered by FUDForum. Page generated in 0.24414 seconds
