Exception when unlocking windows' screensaver [message #662164] |
Tue, 29 March 2011 10:41  |
Hi.
One of our users sometimes gets a Graphic is disposed exception when he
unlocks the screensaver while our RCP application is running. To be
clear, the user leaves the PC on with our application running at night,
the screensaver starts and when he returns back the next day and unlocks
the screensaver the error pops out. The application then shows some
other weird behaviour but I think it is all related to that graphic
disposed error.
This is the stack trace:
org.eclipse.swt.SWTException: Graphic is disposed
at org.eclipse.swt.SWT.error(SWT.java:3884)
at org.eclipse.swt.SWT.error(SWT.java:3799)
at org.eclipse.swt.SWT.error(SWT.java:3770)
at org.eclipse.swt.graphics.Image.getBounds(Image.java:1154)
at org.eclipse.swt.custom.CTabItem.drawSelected(CTabItem.java:3 77)
at org.eclipse.swt.custom.CTabItem.onPaint(CTabItem.java:807)
at org.eclipse.swt.custom.CTabFolder.drawTabArea(CTabFolder.jav a:1147)
at org.eclipse.swt.custom.CTabFolder.onPaint(CTabFolder.java:23 06)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:328)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:14 25)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4001 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4602 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:24 10)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3471)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at com.rtrms.amoeba.internal.Application.run(Application.java:2 5)
at
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hodWithException(EclipseAppContainer.java:574)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
The exception is caused by a WM_PAINT event, I guess this is a general
redraw caused by the screensaver. I can't figure out if it is caused by
something the application is doing or if it is a framework bug. The
application does some background tasks over night involving also closing
and reopening views automatically but it doesn't dispose anything on its
own.
Has anyone encountered something similar ?
Marco.
Re: Exception when unlocking windows' screensaver [message #662185 is a reply to message #662164] |
Tue, 29 March 2011 12:01  |
On 29/03/11 8:11 PM, Marco Maccaferri wrote:
> Hi.
> disposed error.
> at
> at
> at
> at
> at
> at
> at
> at
> own.
> Regards,
> Marco.
This belongs to swt forum. CC-ing...
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
FUDForum. Page generated in 0.08812 seconds
