Home » Language IDEs » PHP Development Tools (PDT) » How to connect to my local database server
How to connect to my local database server [message #662104] Tue, 29 March 2011 06:43 Go to next message
I am new to Eclipse PDT.
I want to make database applications with php and Mysql.
But I do not know how to connect Eclipse with my local database server.
I thought that this command would do the job but it didn't work.
mysql_connect("localhost","username","password");
I take the following error:
PHP Fatal error: Call to undefined function mysql_connect() in /home/pinkonomy/workspace/aaa/soc.php on line 4
Any suggestions please?
Is there any plug in that connects Eclipse PDT with the database server?
Thanks for your time.
[Updated on: Tue, 29 March 2011 06:50] by Moderator
Re: How to connect to my local database server [message #662114 is a reply to message #662104] Tue, 29 March 2011 08:13 Go to previous messageGo to next message
On 2011-03-29 12:43, pinkonomy@gmail.com wrote:
> I want to make database application with php and Mysql.
Is same thing working from console?
What is the result of this command?
If not please double check Your connection settings.
Few, some are commercial,
There is quite good:
DBViewer Plugin 1.2.2.v20101009 zigen.plugin.future.feature.group
but once You learn to use console then You will never use anything else.
/dmc
Re: How to connect to my local database server [message #662116 is a reply to message #662114] Tue, 29 March 2011 08:21 Go to previous messageGo to next message
No,from the console when I write : mysql -uusername -ppassword I can connect to my database server.
Re: How to connect to my local database server [message #662133 is a reply to message #662116] Tue, 29 March 2011 09:15 Go to previous messageGo to next message
Ok, so server is running correctly.
According to manual:
mysql_connect (...) Returns a MySQL link identifier on success or FALSE on failure.
what is the result of something like this?
$conn = mysql_connect(...);
var_dump($conn, mysql_error());
Connection error will be reported by mysql_error.
If connection works from console then it should from php, eclipse has nothing to
that.
/dmc
Re: How to connect to my local database server [message #662135 is a reply to message #662133] Tue, 29 March 2011 09:32 Go to previous messageGo to next message
I take again the same error:PHP Fatal error: Call to undefined function mysql_connect() in /home/pinkonomy/workspace/aaa/soc.php on line 3
I also googled it and found that I should uncomment the
extension=mysql.so in php.ini.
I also did it but nothing worked for me.
Re: How to connect to my local database server [message #662148 is a reply to message #662135] Tue, 29 March 2011 10:14 Go to previous messageGo to next message
Anyone else help me?
Re: How to connect to my local database server [message #662644 is a reply to message #662135] Thu, 31 March 2011 08:00 Go to previous messageGo to next message
> I also googled it and found that I should uncomment the extension=mysql.so in
> php.ini.
Run phpinfo() and make sure that You configured mysql properly, if not google
again for some tutorials. This is not PDT or Eclipse related problem, so this is
not best place to ask for some system related advices.
best regards
/dmc
Re: How to connect to my local database server [message #777179 is a reply to message #662644] Mon, 09 January 2012 20:25 Go to previous messageGo to next message
I am not so sure about not being an Eclipse nor PDT issue. I have the same problem today with an script that fails similar way but just when running into Eclipse. When invoked from command line it works fine. So I think its clear an Eclipse/PDT issue.
Re: How to connect to my local database server [message #778061 is a reply to message #777179] Wed, 11 January 2012 06:08 Go to previous message
> Eclipse/PDT issue.
Most such problems are caused by configuration, so first be sure that your have
needed module. CLI usually uses different configuration or even different
version of PHP.
Of course you can be right about this issue, but first check simple things :)
/dmc
Previous Topic:PDT 3.0.2 Eclipse Update Site ?
Next Topic:mysql_connect undefined when running script from Eclipse
Current Time: Thu Jul 24 18:49:11 EDT 2025
Powered by FUDForum. Page generated in 0.04745 seconds
