Home » Eclipse Projects » WindowBuilder » Focus loss(Eclipse will lose its focus if components are dragged very quickly.)
Focus loss [message #660215] |
Thu, 17 March 2011 08:20  |
Hi to you all,
i think there is a problem when components are dragged from the palette to the editors pane. If you do this very quickly, eclipse will lose its focus to the application window behind. To get back the focus again, you have to select eclipse in the task bar. Although I think this is no big deal, the behavior is sometimes very annoying.
Johannes
Re: Focus loss [message #662283 is a reply to message #662205] |
Wed, 30 March 2011 01:28  |
Although I can reproduce it with a simple panel containing just one JLabel, the error occurs more often if you try with a panel where a bunch of components is placed on it. Below you can find my test case. Just select a JButton of your choice and make some quick clicks on property enabled. You will soon get the error.
import javax.swing.JPanel;
import javax.swing.JButton;
public class TestPanel extends JPanel {
* Create the panel.
public TestPanel() {
setLocation(-236, -26);
setLayout(null);
JPanel panel = new JPanel();
panel.setBounds(77, 60, 199, 330);
add(panel);
panel.setLayout(null);
JButton btnNewButton = new JButton("New button");
btnNewButton.setBounds(10, 9, 89, 23);
panel.add(btnNewButton);
JButton btnNewButton_1 = new JButton("New button");
btnNewButton_1.setBounds(10, 41, 89, 23);
panel.add(btnNewButton_1);
JButton btnNewButton_2 = new JButton("New button");
btnNewButton_2.setBounds(10, 73, 89, 23);
panel.add(btnNewButton_2);
JButton btnNewButton_3 = new JButton("New button");
btnNewButton_3.setBounds(10, 105, 89, 23);
panel.add(btnNewButton_3);
JButton btnNewButton_4 = new JButton("New button");
btnNewButton_4.setBounds(10, 137, 89, 23);
panel.add(btnNewButton_4);
JButton btnNewButton_5 = new JButton("New button");
btnNewButton_5.setBounds(10, 169, 89, 23);
panel.add(btnNewButton_5);
JButton btnNewButton_6 = new JButton("New button");
btnNewButton_6.setBounds(10, 201, 89, 23);
panel.add(btnNewButton_6);
JButton btnNewButton_7 = new JButton("New button");
btnNewButton_7.setBounds(10, 233, 89, 23);
panel.add(btnNewButton_7);
JButton btnNewButton_8 = new JButton("New button");
btnNewButton_8.setBounds(10, 265, 89, 23);
panel.add(btnNewButton_8);
JButton btnNewButton_9 = new JButton("New button");
btnNewButton_9.setBounds(10, 297, 89, 23);
panel.add(btnNewButton_9);
JButton btnNewButton_10 = new JButton("New button");
btnNewButton_10.setBounds(105, 41, 89, 23);
panel.add(btnNewButton_10);
JButton btnNewButton_11 = new JButton("New button");
btnNewButton_11.setBounds(105, 9, 89, 23);
panel.add(btnNewButton_11);
JButton btnNewButton_12 = new JButton("New button");
btnNewButton_12.setBounds(105, 73, 89, 23);
panel.add(btnNewButton_12);
JButton btnNewButton_13 = new JButton("New button");
btnNewButton_13.setBounds(105, 105, 89, 23);
panel.add(btnNewButton_13);
JButton btnNewButton_14 = new JButton("New button");
btnNewButton_14.setBounds(105, 137, 89, 23);
panel.add(btnNewButton_14);
JButton btnNewButton_15 = new JButton("New button");
btnNewButton_15.setBounds(105, 169, 89, 23);
panel.add(btnNewButton_15);
JButton btnNewButton_16 = new JButton("New button");
btnNewButton_16.setBounds(105, 201, 89, 23);
panel.add(btnNewButton_16);
JButton btnNewButton_17 = new JButton("New button");
btnNewButton_17.setBounds(105, 233, 89, 23);
panel.add(btnNewButton_17);
JButton btnNewButton_18 = new JButton("New button");
btnNewButton_18.setBounds(105, 265, 89, 23);
panel.add(btnNewButton_18);
JButton button = new JButton("New button");
button.setBounds(105, 297, 89, 23);
panel.add(button);
JPanel panel_1 = new JPanel();
panel_1.setLayout(null);
panel_1.setBounds(292, 60, 199, 330);
add(panel_1);
JButton button_1 = new JButton("New button");
button_1.setBounds(10, 9, 89, 23);
panel_1.add(button_1);
JButton button_2 = new JButton("New button");
button_2.setBounds(10, 41, 89, 23);
panel_1.add(button_2);
JButton button_3 = new JButton("New button");
button_3.setBounds(10, 73, 89, 23);
panel_1.add(button_3);
JButton button_4 = new JButton("New button");
button_4.setBounds(10, 105, 89, 23);
panel_1.add(button_4);
JButton button_5 = new JButton("New button");
button_5.setBounds(10, 137, 89, 23);
panel_1.add(button_5);
JButton button_6 = new JButton("New button");
button_6.setBounds(10, 169, 89, 23);
panel_1.add(button_6);
JButton button_7 = new JButton("New button");
button_7.setBounds(10, 201, 89, 23);
panel_1.add(button_7);
JButton button_8 = new JButton("New button");
button_8.setBounds(10, 233, 89, 23);
panel_1.add(button_8);
JButton button_9 = new JButton("New button");
button_9.setBounds(10, 265, 89, 23);
panel_1.add(button_9);
JButton button_10 = new JButton("New button");
button_10.setBounds(10, 297, 89, 23);
panel_1.add(button_10);
JButton button_11 = new JButton("New button");
button_11.setBounds(105, 41, 89, 23);
panel_1.add(button_11);
JButton button_12 = new JButton("New button");
button_12.setBounds(105, 9, 89, 23);
panel_1.add(button_12);
JButton button_13 = new JButton("New button");
button_13.setBounds(105, 73, 89, 23);
panel_1.add(button_13);
JButton button_14 = new JButton("New button");
button_14.setBounds(105, 105, 89, 23);
panel_1.add(button_14);
JButton button_15 = new JButton("New button");
button_15.setBounds(105, 137, 89, 23);
panel_1.add(button_15);
JButton button_16 = new JButton("New button");
button_16.setBounds(105, 169, 89, 23);
panel_1.add(button_16);
JButton button_17 = new JButton("New button");
button_17.setBounds(105, 201, 89, 23);
panel_1.add(button_17);
JButton button_18 = new JButton("New button");
button_18.setBounds(105, 233, 89, 23);
panel_1.add(button_18);
JButton button_19 = new JButton("New button");
button_19.setBounds(105, 265, 89, 23);
panel_1.add(button_19);
JButton button_20 = new JButton("New button");
button_20.setBounds(105, 297, 89, 23);
panel_1.add(button_20);
Current Time: Fri Jul 25 21:51:51 EDT 2025
Powered by FUDForum. Page generated in 0.03729 seconds
