Home » Eclipse Projects » EclipseLink » MOXy - xlink reference to previously marshalled objects
MOXy - xlink reference to previously marshalled objects [message #661234] Wed, 23 March 2011 12:08 Go to next message
Hi!
I'm making a service that returns an Owner. The Owner can own Land and Buildings and each Building stands on a piece of Land, so the XML tree looks something like this:
Owner
  Land
  Land
  Building
    Land
  Building
    Land
Now, many Buildings may stand on the same piece of Land and the Land may or may not be owned by the Owner. I don't want to have several instances of the same Land object in my response. Instead, I'd like it if only the first instance was marshalled in full and the rest was only an xlink reference to the first.
Is this possible?
[Updated on: Thu, 24 March 2011 09:46] by Moderator
Re: MOXy - xlink reference to previously marshalled objects [message #661615 is a reply to message #661234] Fri, 25 March 2011 11:07 Go to previous messageGo to next message
You could leverage @XmlID/@XmlIDREF to do the following:
Land
Land will need an id property annotated with @XmlID:
import javax.xml.bind.annotation.XmlAttribute;
import javax.xml.bind.annotation.XmlID;
public class Land {
    private String id;
    @XmlID
    @XmlAttribute
    public String getId() {
        return id;
    public void setId(String id) {
        this.id = id;
Building
The land property on building will be annotated with @XmlIDREF:
import javax.xml.bind.annotation.XmlIDREF;
public class Building {
    private Land land;
    @XmlIDREF
    public Land getLand() {
        return land;
    public void setLand(Land land) {
        this.land = land;
B]Owner[/B]
import java.util.ArrayList;
import java.util.List;
import javax.xml.bind.annotation.XmlRootElement;
import javax.xml.bind.annotation.XmlType;
@XmlRootElement
@XmlType(propOrder={"building", "land"})
public class Owner {
    private List<Land> land = new ArrayList<Land>();
    private List<Building> building = new ArrayList<Building>();
    public List<Land> getLand() {
        return land;
    public void setLand(List<Land> land) {
        this.land = land;
    public List<Building> getBuilding() {
        return building;
    public void setBuilding(List<Building> building) {
        this.building = building;
Demo
import javax.xml.bind.JAXBContext;
import javax.xml.bind.Marshaller;
public class Demo {
    public static void main(String[] args) throws Exception {
        Owner owner = new Owner();
        Land land1 = new Land();
        land1.setId("1");
        Building building1 = new Building();
        building1.setLand(land1);
        owner.getBuilding().add(building1);
        owner.getLand().add(land1);
        Land land2 = new Land();
        land2.setId("2");
        Building building2 = new Building();
        building2.setLand(land2);
        owner.getBuilding().add(building2);
        owner.getLand().add(land2);
        JAXBContext jc = JAXBContext.newInstance(Owner.class);
        Marshaller marshaller = jc.createMarshaller();
        marshaller.setProperty(Marshaller.JAXB_FORMATTED_OUTPUT, true);
        marshaller.marshal(owner, System.out);
Output
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<owner>
    <building>
        <land>1</land>
    </building>
    <building>
        <land>2</land>
    </building>
    <land id="1"/>
    <land id="2"/>
</owner>
-Blaise
Re: MOXy - xlink reference to previously marshalled objects [message #661641 is a reply to message #661615] Fri, 25 March 2011 12:26 Go to previous messageGo to next message
Thanks a lot for your very detailed reply, Blaise! However, there is a problem:
To illustrate, let's add a label to the land:
    private String label;
    @XmlElement
    public String getLabel() {
      return label;
    public void setLabel(String label) {
      this.label = label;
And make it so the Owner does not own land2:
    land1.setId("1");
    land1.setLabel("land 1");
    land2.setId("2");
    land2.setLabel("land 2");
    //owner.getLand().add(land2);
We get the following output:
<owner>
    <building>
        <land>1</land>
    </building>
    <building>
        <land>2</land>
    </building>
    <land id="1">
        <label>land 1</label>
    </land>
</owner>
As you can see, it's impossible to know the label of land2. I need every Land object to be fully marshalled exactly once. Is there a solution for this?
Re: MOXy - xlink reference to previously marshalled objects [message #661661 is a reply to message #661234] Fri, 25 March 2011 16:11 Go to previous messageGo to next message
Hello Again,
I apologize for missing that part of your question. The following will give you the type of behaviour you are looking for:
Land
Nothing special needs to be done for the Land class:
public class Land {
    private String address;
    public String getAddress() {
        return address;
    public void setAddress(String address) {
        this.address = address;
Building
The land property on Building is where all the magic happens. We will use an XmlAdapter on this property.
import javax.xml.bind.annotation.adapters.XmlJavaTypeAdapter;
    private Land land;
    @XmlJavaTypeAdapter(MarshalAdapter.class)
        return land;
        this.land = land;
MarshalAdapter
This is what the XmlAdapter will look like. This XmlAdapter requires the land list from the Owner object be set on it. You will see how this is done in the code for Demo.
import javax.xml.bind.annotation.adapters.XmlAdapter;
public class MarshalAdapter extends XmlAdapter<AdaptedLand, Land> {
    private List<Land> ownersLand;
    public MarshalAdapter() {
    public MarshalAdapter(List<Land> ownersLand) {
        this.ownersLand = ownersLand;
    public Land unmarshal(AdaptedLand v) throws Exception {
        return null;
    public AdaptedLand marshal(Land v) throws Exception {
        AdaptedLand adaptedLand = new AdaptedLand();
        if(ownersLand.contains(v)) {
            adaptedLand.setOwnerLandIndex(String.valueOf(ownersLand.indexOf(v)));
        } else {
            adaptedLand.setLand(v);
        return adaptedLand;
AdaptedLand
This class is leveraged by the XmlAdapter:
import org.eclipse.persistence.oxm.annotations.XmlPath;
public class AdaptedLand {
    private Land land;
    private String ownerLandIndex;
    @XmlPath(".")
        return land;
        this.land = land;
    @XmlAttribute
    public String getOwnerLandIndex() {
        return ownerLandIndex;
    public void setOwnerLandIndex(String id) {
        this.ownerLandIndex = id;
Owner
@XmlRootElement
        return land;
        this.land = land;
        return building;
Demo
public class Demo {
        land1.setAddress("123 Any Street");
        land2.setAddress("456 Another Road");
        marshaller.setAdapter(new MarshalAdapter(owner.getLand()));
Output
<owner>
   <building>
      <land ownerLandIndex="0"/>
   </building>
   <building>
      <land>
         <address>456 Another Road</address>
      </land>
   </building>
   <land>
      <address>123 Any Street</address>
   </land>
</owner>
-Blaise
Re: MOXy - xlink reference to previously marshalled objects [message #661871 is a reply to message #661661] Mon, 28 March 2011 07:25 Go to previous message
Heh, no need to apologize. Your example is exactly what I need. Very thorough and easy to follow. Thanks, Blaise!
Previous Topic:Some questions about logging
Next Topic:Toplink to eclipselink upgrade issue
Current Time: Thu Sep 25 22:37:55 EDT 2025
Powered by FUDForum. Page generated in 0.04780 seconds
