Home » Eclipse Projects » Rich Client Platform (RCP) » Product configuration (features included)
Product configuration (features included) [message #661624] Fri, 25 March 2011 11:29 Go to next message
I'm new in the RCP world and may my question is trivial ...
I want to build an RCP application, with some standard views, help management, etc. I want to use a feature base product definition as I will use Maven with Tycho. My question is :
How must I organize my dependancies with features and plugins to be sur to don't add a lot of unused stuff ?
For example, in my product definition, I first added these features :
- myfeature
- org.eclipse.rcp
And this works with my Run Configuration, but not with the Tycho built (Missing required bundle xxx messages).
When I added in my product definition the features :
- org.eclipse.plateform
- org.equinox.p2.user.ui
my Tycho built work, but I have some new menus (Search, etc) that I don't want ! Confused
Thus, How must I organize my dependancies to have the minimum of stuff included in my final product ?
I thought to create a new feature which will contains only the eclipse standard plugins that I want. Is it a good way to do ? Have you any other ideas ?
Re: Product configuration (features included) [message #661782 is a reply to message #661624] Sun, 27 March 2011 15:54 Go to previous messageGo to next message
Hi Jod,
Welcome to the world of Release Engineering. If you want to build using
features you have the option to re-use other features from eclipse. This
makes the update and the releng easier but it could come at the cost of extra
unwanted user interface elements.
You can also try to figure out which other plugins you need and instead of
using the eclipse feature that holds this bundle you can make your own
"additional" feature and put that bundle in there.
Whatever you choose, you will need to spent time figuring out your perfect
configuration. There is tooling that will help you but the engineering has to
be done by you.
Tools: pde, marketplace feature explorer, buckminster, pde plugin
visualiziation, tycho
Wim Jongman
> - myfeature
> - org.eclipse.rcp
want ! :?
ideas ?
Re: Product configuration (features included) [message #661817 is a reply to message #661782] Mon, 28 March 2011 02:37 Go to previous messageGo to next message
Thanks Wim,
Your answer confirm what I tought. I will check out these tools and spend some more time to study our needs, before beginning to code !
Re: Product configuration (features included) [message #661901 is a reply to message #661624] Mon, 28 March 2011 09:21 Go to previous messageGo to next message
I'll just add to what Wim said and mention that if org.eclipse.rcp is
too big for your RCP app, it is acceptable to create a your.domain.rcp
feature and include only the RCP plugins you need. Then your feature
includes your RCP feature. You just have to remember to manage your RCP
feature.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Product configuration (features included) [message #661911 is a reply to message #661901] Mon, 28 March 2011 09:59 Go to previous message
Thanks for this advise.
I will may follow it as I have constraints on size.
Previous Topic:Open View in separate Window/Shell
Next Topic:Missing Constraint: Require-Bundle: org.eclipse.equinox.common; bundle-version="[3.5.0,4.0.0)
Current Time: Sun Jul 27 02:15:00 EDT 2025
Powered by FUDForum. Page generated in 0.03429 seconds
