Home » Newcomers » Newcomers » Need both JAVA and PHP - will Eclipse EE do both?
Need both JAVA and PHP - will Eclipse EE do both? [message #661585] Fri, 25 March 2011 09:52 Go to next message
I saw the Compare Packages page:
http://www.eclipse.org/downloads/compare.php
Will the Eclipse JAVA EE IDE version handle both JAVA and PHP ?
http://www.eclipse.org/downloads/packages/eclipse-ide-java-e e-developers/heliossr1
Or do I need to install the different versions (one Java and the other PHP) ?
Thanks Smile
[Updated on: Fri, 25 March 2011 09:53] by Moderator
Re: Need both JAVA and PHP - will Eclipse EE do both? [message #661605 is a reply to message #661585] Fri, 25 March 2011 10:00 Go to previous messageGo to next message
> Thanks :)
Yes. There is Eclipse PDT software you should add to Java EE in order to
use PHP (or vice versa--it's up to you). Once installed and running, go
to Help -> Install New Software.
When you install Eclipse, be sure to fix up eclipse.ini to point
directly at a JDK (not merely a JRE) as per
http://wiki.eclipse.org/Eclipse.ini .
Re: Need both JAVA and PHP - will Eclipse EE do both? [message #661706 is a reply to message #661605] Sat, 26 March 2011 10:18 Go to previous message
Great, thanks so much Smile
Previous Topic: survey about netbeans and eclipse for my dissertation
Next Topic:Trouble getting access to an nsIDocShell instance
Current Time: Fri Nov 07 03:55:00 EST 2025
Powered by FUDForum. Page generated in 0.09397 seconds
