Home » Eclipse Projects » Rich Client Platform (RCP) » Missing Constraint: Require-Bundle: org.eclipse.equinox.common; bundle-version="[3.5.0,4.0.0)
Missing Constraint: Require-Bundle: org.eclipse.equinox.common; bundle-version="[3.5.0,4.0.0) [message #661495] Thu, 24 March 2011 18:42 Go to next message
Hi !
I am currently reading the book Eclipse RCP. I went through the chapters 1 to 14 without any big issue, but now I am completely blocked at chapter 17.
The problem is the following :
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.equinox.common; bundle-version="[3.5.0,4.0.0)"
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.equinox.common; bundle-version="[3.2.0,4.0.0)"
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime_3.5.0.v20090525.jar/ was not resolved.
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.update.configurator_3.3.0.v20090312.jar/ was not resolved.
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2011-03-24 23:30:06.768
!MESSAGE Missing required bundle org.eclipse.equinox.common_[3.2.0,4.0.0).
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!MESSAGE Missing optionally required bundle org.eclipse.core.runtime.compatibility.auth_[3.2.0,4.0.0).
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2011-03-24 23:30:06.770
!MESSAGE Missing required bundle org.eclipse.equinox.app_[1.0.0,2.0.0).
!MESSAGE Missing imported package org.eclipse.core.internal.runtime.auth_0.0.0.
!SUBENTRY 1 org.eclipse.osgi 2 0 2011-03-24 23:30:06.770
!MESSAGE Bundle org.eclipse.update.configurator_3.3.0.v20090312 [2] was not resolved.
!SUBENTRY 2 org.eclipse.update.configurator 2 0 2011-03-24 23:30:06.770
I have already spent hours on this issue. I can reproduce it under both MacOS X and Windows, with a clean Eclipse installation (I tried both Galileo and Helios). What is especially ununderstandable is that the difference between chapter 14 and 17 is really not that big.
I am really stuck and would appreciate any help...
Thanks !
Best regards
Olivier
[Updated on: Sun, 18 December 2022 09:16] by Moderator
Re: Missing Constraint: Require-Bundle: org.eclipse.equinox.common; bundle-version="[3.5.0,4.0. [message #661730 is a reply to message #661495] Sat, 26 March 2011 16:27 Go to previous messageGo to next message
Hi again !
Could anyone help me with this issue ? I am really blocked. Thanks in advance for any hint !
Re: Missing Constraint: Require-Bundle: org.eclipse.equinox.common; bundle-version="[3.5.0,4.0. [message #661897 is a reply to message #661495] Mon, 28 March 2011 09:17 Go to previous messageGo to next message
What if you delete and re-create your launch config? Then if that
doesn't work, have a look at your launch config and make sure
org.eclipse.equinox.common bundle is included.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Missing Constraint: Require-Bundle: org.eclipse.equinox.common; bundle-version="[3.5.0,4.0. [message #662002 is a reply to message #661897] Mon, 28 March 2011 16:06 Go to previous message
Many thanks Paul, you put me on the right track.
I used to right click on my product, and do "Run as / Eclipse application" from there. It used to work with the previous samples from the book, but starting with chapter 16, it doesn't anymore obviously.
I have created a brand new configuration and it worked. I still have to investigate what's wrong exactly, but at least my application is starting now. Many plugins I don't need are contributing to the toolbars, indicating that the application is still carrying too much plugins, and I will have to look into this too.
Thanks again !
Previous Topic:Product configuration (features included)
Next Topic:Dynamic menu pagination
Current Time: Wed Jul 23 12:22:19 EDT 2025
Powered by FUDForum. Page generated in 0.05291 seconds
