Home » Eclipse Projects » WindowBuilder » WindowsBuilder deletes method called from action listener
WindowsBuilder deletes method called from action listener [message #661237] Wed, 23 March 2011 12:19 Go to next message
I just started playing with WindowBuilder after using NetBeans for GUI construction for a long time.
I have version 0.9.0.r36x201102111130 installed
I have only used it for a couple days, and it just torched a bunch of my work!
I had several methods that were called from actionlisteners on several toolbar buttons. I decided to move things around and deleted these buttons.
Not only did WindowBuilder delete the actionlisteners (as expected), it also deleted the methods I CALLED from the action listeners! (several hundred lines of functionality I would have liked to retain.)
Of course I have backups, but I am alarmed as it seems very bizarre that it would do this silently and as the default behavior.
My google-fu was not high enough today to find any other mentions of this behavior.
Can anyone tell me if this is a bug? Or is this by design? If so can this be disabled? Are there any other oddities like this I should know about before WindowBuilder goes deleting my code all willy nilly?
Thanks in advance for any insights!
-- Thaddeus
Re: WindowsBuilder deletes method called from action listener [message #661243 is a reply to message #661237] Wed, 23 March 2011 12:46 Go to previous messageGo to next message
This is feature.
Look on "Delete sub event handler methods" option in preferences.
http://dl.dropbox.com/u/76691/Eclipse/images/Screenshot_20110323_124429.png
Re: WindowsBuilder deletes method called from action listener [message #661248 is a reply to message #661243] Wed, 23 March 2011 13:00 Go to previous message
Thanks for the quick response!
Previous Topic:WindowBuilder internal error when manipulating boolean properties.
Next Topic:Source code release date?
Current Time: Wed Jul 23 23:02:44 EDT 2025
Powered by FUDForum. Page generated in 0.03908 seconds
