Home » Modeling » M2T (model-to-text transformation) » [JET] Update input xml dynamically in JET
[JET] Update input xml dynamically in JET [message #661024] Tue, 22 March 2011 14:56 Go to next message
I'm a new JET user. Can anyone let me know if it is possible to update the input xml (set the content value of some node) dynamically in JET template? I tried <c:addTextElement>, but it seems not the right tag to use. Nothing was changed in the input xml file after the code generation was done.
Thanks a lot,
William
Re: [JET] Update input xml dynamically in JET [message #661027 is a reply to message #661024] Tue, 22 March 2011 15:07 Go to previous messageGo to next message
William:
You are close. JET doesn't update anything automatically. If you want to update a file (say the input model), you have to use a take like ws:file (that invokes a template to specify the content).
So, your sequence of actions would be:
<c:addTextElement > ... or whatever
<ws:file path="...input path..." template="templates/updateInput.jet" />
and updateInput.jet would contain:
<c:dump select="/*" />
c:dump was really intended for debugging. It sometimes does a less than perfect job of representing the input as XML (especially if the input isn't XML).
Lastly, if you are invoking the JET transform from the Eclipse Run UI, or from JET2Platform.runtTransformOnResource(), then the JET variable org.eclipse.jet.resource.fullPath contains the right value for the path attribute on <ws:file>
<ws:file path="{org.eclipse.jet.resource.fullPath}" ... />
Re: [JET] Update input xml dynamically in JET [message #661047 is a reply to message #661027] Tue, 22 March 2011 17:45 Go to previous messageGo to next message
Hi Paul,
This is perfect. Thank you so much.
BTW, does this mean that I have to overwrite the whole input document even if I just want to update a small portion (one element) of it?
William
Re: [JET] Update input xml dynamically in JET [message #661048 is a reply to message #661024] Tue, 22 March 2011 17:50 Go to previous messageGo to next message
Hi Paul,
William
Re: [JET] Update input xml dynamically in JET [message #661074 is a reply to message #661048] Tue, 22 March 2011 20:36 Go to previous message
William:
Yes, ws:file writes the whole file, no partial update.
Paul
Previous Topic:WorkflowEngine run
Next Topic:[Acceleo] white lines into code and code move
Current Time: Wed Jul 23 13:31:37 EDT 2025
Powered by FUDForum. Page generated in 0.41478 seconds
