Home » Modeling » GMF (Graphical Modeling Framework) » java.lang.IllegalArgumentException: can't find ID print(GMF, Eclipse 3.6)
java.lang.IllegalArgumentException: can't find ID print [message #660983] Tue, 22 March 2011 10:57 Go to next message
Hallo,
I created an RCP application, that works fine.
I added the plugins of the Yakindu Editor (Statechart Tools of the enterprise Itemis) to my RCP application.
The RCP works fine , even with the added plugins of Yakindu.
But when i try to create the first Statemachine Diagram, it can't open. I get the following error message: could not open the editor: can't find ID print.
When i try the same (create a statemachine diagram) later, after the first error, that works fine.
Can someone tell me, what i do wrong?
How can i solve this problem ?
Best regards
Ida
Error details
	at org.eclipse.jface.action.ContributionManager.insertBefore(ContributionManager.java:359)
	at org.eclipse.jface.action.SubContributionManager.insertBefore(SubContributionManager.java:176)
	at org.eclipse.jface.action.SubContributionManager.insertBefore(SubContributionManager.java:167)
	at statemachine.diagram.part.StatemachineDiagramActionBarContributor.init(StatemachineDiagramActionBarContributor.java:55)
	at org.eclipse.ui.internal.EditorManager.createEditorActionBars(EditorManager.java:323)
	at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:790)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
	at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
	at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
	at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
	at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
	at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1254)
	at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1207)
	at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1606)
	at org.eclipse.ui.internal.PartStack.add(PartStack.java:497)
	at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
	at org.eclipse.ui.internal.PartStack.add(PartStack.java:483)
	at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
	at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
	at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
	at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
	at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:778)
	at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:677)
	at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:638)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2860)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2768)
	at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2760)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2711)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2707)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2691)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2682)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
	at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:365)
	at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:168)
	at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:229)
	at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:208)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:274)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:250)
	at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:373)
	at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.java:526)
	at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
	at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:845)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:843)
	at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1131)
	at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1235)
	at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:264)
	at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:258)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:298)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
	at com.berner_mattner.messina.Application.start(Application.java:121)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Re: java.lang.IllegalArgumentException: can't find ID print [message #661345 is a reply to message #660983] Thu, 24 March 2011 06:36 Go to previous messageGo to next message
As you can see by stacktrace, the error is in
statemachine.diagram.part.StatemachineDiagramActionBarContri butor.init(StatemachineDiagramActionBarContributor.java:55)
Inspect this code, I think you have to register the PRINT Action in your ApplicationActionBarAdvisor.makeActions() method.
HTH
Giovanni
Re: java.lang.IllegalArgumentException: can't find ID print [message #663064 is a reply to message #660983] Sat, 02 April 2011 23:19 Go to previous messageGo to next message
Hello Ida,
I faced the same problem but I fixed it by adding
put this piece of code
menuX.add(getAction(ActionFactory.PRINT.getId()));
in the class
DiagramEditorActionBarAdvisor.java
in the function
protected void fillMenuBar(IMenuManager menu)
I hope it solves your problem.
Saad Bin Abid
Re: java.lang.IllegalArgumentException: can't find ID print [message #1394107 is a reply to message #663064] Fri, 04 July 2014 16:13 Go to previous message
Worked for me, too. Thanks, Saad.
Previous Topic:Customizing Workbench by Adding Title
Next Topic:Error when moving from Kepler to Luna
Current Time: Thu Jul 24 23:15:06 EDT 2025
Powered by FUDForum. Page generated in 0.07702 seconds
