Home » Archived » BIRT » BIRT report parameters help
BIRT report parameters help [message #660969] Tue, 22 March 2011 10:20 Go to next message
On scripting BIRT report parameter, I can get parameter value:
example:
params["name"].value
As you can set that your parameter can be a list, and when adding some elements to list, we can put value and display text for parameter.
So, my question is:
Can I somehow script report parameter to get a display text of parameter element when choosing it, not value at this time?
Hope you understood my question.
Thanks, and regards,
Re: BIRT report parameters help [message #661067 is a reply to message #660969] Tue, 22 March 2011 19:52 Go to previous message
If the list does not have multi-select checked you should be able to use:
params["name"].displayText;
Jason
On 3/22/2011 10:20 AM, mkrivic wrote:
> example:
> So, my question is:
Previous Topic:Exception Stack Trace
Next Topic:separation between the cells in reports
Current Time: Wed Jul 23 09:29:09 EDT 2025
Powered by FUDForum. Page generated in 0.12115 seconds
