CDO server resource editor error [message #660695] |
Mon, 21 March 2011 05:08  |
Hi All,
i have a derby DB,which contain persisted EMF objects,when i do the following:
1- open a session
2- register my EMF model
3-enable legacy mode
4- open transaction, which open resource under it
5- then when i click open editor
i got the following exception, despite the same DB is working in another colleague machine with win 7, mine is XP:
!MESSAGE org.eclipse.emf.ecore.impl.EGenericTypeImpl cannot be cast to org.eclipse.emf.ecore.EModelElement
!STACK 0
java.lang.ClassCastException: org.eclipse.emf.ecore.impl.EGenericTypeImpl cannot be cast to org.eclipse.emf.ecore.EModelElement
at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.getMe taInstance(MetaDataManager.java:84)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ob jectTypeCache.getObjectType(ObjectTypeCache.java:108)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab stractHorizontalMappingStrategy.readObjectType(AbstractHoriz ontalMappingStrategy.java:71)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.readO bjectType(DBStoreAccessor.java:158)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.getOb jectType(DBStoreAccessor.java:175)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.readR evision(DBStoreAccessor.java:200)
at org.eclipse.emf.cdo.internal.server.Repository.loadRevisions (Repository.java:418)
at org.eclipse.emf.cdo.internal.common.revision.CDORevisionMana gerImpl.loadRevisions(CDORevisionManagerImpl.java:365)
at org.eclipse.emf.cdo.internal.common.revision.CDORevisionMana gerImpl.getRevisions(CDORevisionManagerImpl.java:268)
at org.eclipse.emf.cdo.internal.common.revision.CDORevisionMana gerImpl.getRevision(CDORevisionManagerImpl.java:250)
at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.execute (RevisionInfo.java:132)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.LoadRevis ionsIndication.responding(LoadRevisionsIndication.java:169)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServer Indication.responding(CDOServerIndication.java:126)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOu tput(IndicationWithResponse.java:96)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:285)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:65)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOReadIn dication.execute(CDOReadIndication.java:36)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:240)
at org.eclipse.net4j.signal.Signal.run(Signal.java:146)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unkno wn Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
any ideas here , what will be the main reason for that exception, despite the same data base is working in another machine?
Re: CDO server resource editor error [message #661071 is a reply to message #660695] |
Tue, 22 March 2011 20:22  |
Hi romeh,
Is it possible that you have a different version of the meta model deployed to your local application process than your collegue?
Cheers
/Eike
http://www.esc-net.de
Am 21.03.2011 02:08, schrieb romeh:
> Hi All,
> 1- open a session
> !STACK 0
FUDForum. Page generated in 0.04354 seconds
