[ATL] Replace strange symbols [message #660731] |
Mon, 21 March 2011 08:33  |
Hi, I have a string property to which I want to replace some strange symbols like (ñ, ç) or accents but I have used replaceAll() method and it doesn't work fine.
that is my code:
element.name <- element.name.replaceAll('ñ', 'ny');
element.name <- element.name.replaceAll('ç', 'c');
element.name <- element.name.replaceAll('ó', 'o');
I transform elements with this symbols ('año', 'dirección'...) but the result is the same.
I have try to compare, for each character if it is a strange symbol but comparison returns false. That is:
for (c in element.name.toSequence()) {
if (c = 'ñ') {
... this code is never reached
Any idea ?¿?
Re: [ATL] Replace strange symbols [message #660794 is a reply to message #660731] |
Mon, 21 March 2011 12:07  |
Hi Miguel,
it could be an encoding problem. If what you expect to be a 'ñ' internally is represented by something like '#$%&' your replace/comparison wont work.
Miguel Ll wrote on Mon, 21 March 2011 08:33 | for (c in element.name.toSequence()) {
if (c = 'ñ') {
You could look in the debugger BEFORE you compare c = 'ñ' what values c takes. Maybe you have to check the encoding setting for your import. Do you use XMI? The first line of the XML should specify an encoding.
Sebastian
FUDForum. Page generated in 0.04192 seconds
