Home » Archived » M2M (model-to-model transformation) » [ATL] Replace strange symbols
[ATL] Replace strange symbols [message #660731] Mon, 21 March 2011 08:33 Go to next message
Hi, I have a string property to which I want to replace some strange symbols like (ñ, ç) or accents but I have used replaceAll() method and it doesn't work fine.
that is my code:
element.name <- element.name.replaceAll('ñ', 'ny');
element.name <- element.name.replaceAll('ç', 'c');
element.name <- element.name.replaceAll('ó', 'o');
I transform elements with this symbols ('año', 'dirección'...) but the result is the same.
I have try to compare, for each character if it is a strange symbol but comparison returns false. That is:
for (c in element.name.toSequence()) {
if (c = 'ñ') {
... this code is never reached
Any idea ?¿?
Re: [ATL] Replace strange symbols [message #660744 is a reply to message #660731] Mon, 21 March 2011 08:58 Go to previous messageGo to next message
try regexReplaceAll
Re: [ATL] Replace strange symbols [message #660748 is a reply to message #660744] Mon, 21 March 2011 09:09 Go to previous messageGo to next message
I have tried but it doesn't work... Sad
Re: [ATL] Replace strange symbols [message #660753 is a reply to message #660731] Mon, 21 March 2011 09:32 Go to previous messageGo to next message
Are you sure that the transformation still compiles with those characters ?
Try to delete the .asm file and see if it comes back after a build.
Re: [ATL] Replace strange symbols [message #660776 is a reply to message #660753] Mon, 21 March 2011 10:50 Go to previous messageGo to next message
Yes, I have removed the .asm and it has been re-build without errors and the transformation is executed with the same results.
Re: [ATL] Replace strange symbols [message #660794 is a reply to message #660731] Mon, 21 March 2011 12:07 Go to previous message
Hi Miguel,
it could be an encoding problem. If what you expect to be a 'ñ' internally is represented by something like '#$%&' your replace/comparison wont work.
Miguel Ll wrote on Mon, 21 March 2011 08:33
if (c = 'ñ') {
You could look in the debugger BEFORE you compare c = 'ñ' what values c takes. Maybe you have to check the encoding setting for your import. Do you use XMI? The first line of the XML should specify an encoding.
Sebastian
Previous Topic:[QVTo] Removing an element
Next Topic:[QVTo] Weird thing about Stereotypes application
Current Time: Sun Aug 31 14:40:35 EDT 2025
Powered by FUDForum. Page generated in 0.09012 seconds
