Bundles stored in local repository? [message #660723] |
Mon, 21 March 2011 08:13  |
Originally posted by: jfrantzius.googlemail.com
not having made any practical experiences with Tycho so far,
unfortunately, I'd have a question regarding downloaded bundles.
"Normal" maven dependencies are cached in the local repository once they
were downloaded. Now the question is: does this also hold true for
bundles learned from bundle descriptors, that were e.g. downloaded from
P2 repositories?
I guess they'd have to be "repackaged" as maven artifacts, with some
kind of generated POM in order to facilitate this, so I wonder whether
Tycho does this.
Thanks for any hints,
Jörg
Re: Bundles stored in local repository? [message #660931 is a reply to message #660723] |
Tue, 22 March 2011 07:51   |
When looking at slide 6 from
http://www.slideshare.net/jsievers/building-eclipse-plugins- with-tycho,
it seems that instead bundles are stored in a local p2 repository. Tycho
then seems to provide support for resolving dependencies against that
So in theory, it should be possible to write a maven mojo that has e.g.
the EMF generator as its dependency with
"<packaging>eclipse-plugin</packaging>"?
On 21.03.2011 13:13, Jörg von Frantzius wrote:
> they were downloaded. Now the question is: does this also hold true
> for bundles learned from bundle descriptors, that were e.g. downloaded
> from P2 repositories?
> Tycho does this.
> Jörg
Re: Bundles stored in local repository? [message #717930 is a reply to message #660931] |
Mon, 22 August 2011 14:34  |
You need to use
<plugin>
<groupId>org.sonatype.tycho</groupId>
<artifactId>tycho-maven-plugin</artifactId>
<version>${tycho-version}</version>
<extensions>true</extensions>
</plugin>
for <packaging>eclipse-plugin</packaging>.
Hope this helps.
FUDForum. Page generated in 0.29505 seconds
