Home » Archived » SeMantic Information Logistics Architecture (SMILA) » New SMILA tryout
New SMILA tryout [message #660478] Fri, 18 March 2011 11:11 Go to next message
Hi there,
I just wanted to try out the all new SMILA from trunk.
I ran into several problems:
  • SMILA is not able to find javax.servlet and javax.servlet.http
  • If I run it though, I get a java.lang.ExceptionInInitializerError caused by commons logging (stacktrace below)
Anybody a hint on that?
Martin
	at org.eclipse.smila.management.jmx.client.cmd.task.impl.OperationTask.execute(OperationTask.java:70)
	at org.eclipse.smila.management.jmx.client.cmd.task.impl.OperationTask.execute(OperationTask.java:1)
	at org.eclipse.smila.management.jmx.client.cmd.CmdConsoleImpl.execute(CmdConsoleImpl.java:89)
	at org.eclipse.smila.management.jmx.client.cmd.CmdConsoleImpl.execute(CmdConsoleImpl.java:71)
	at org.eclipse.smila.management.jmx.client.osgi.SMILACommandProvider._smila(SMILACommandProvider.java:100)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.osgi.framework.internal.core.FrameworkCommandInterpreter.execute(FrameworkCommandInterpreter.java:155)
	at org.eclipse.osgi.framework.internal.core.FrameworkConsole.docommand(FrameworkConsole.java:156)
	at org.eclipse.osgi.framework.internal.core.FrameworkConsole.runConsole(FrameworkConsole.java:141)
	at org.eclipse.osgi.framework.internal.core.FrameworkConsole.run(FrameworkConsole.java:105)
	at java.lang.Thread.run(Thread.java:662)
Caused by: org.apache.commons.logging.LogConfigurationException: User-specified log class 'org.apache.commons.logging.impl.Log4JLogger' cannot be found or is not useable.
	at org.apache.commons.logging.impl.LogFactoryImpl.discoverLogImplementation(LogFactoryImpl.java:874)
	at org.apache.commons.logging.impl.LogFactoryImpl.newInstance(LogFactoryImpl.java:604)
	at org.apache.commons.logging.impl.LogFactoryImpl.getInstance(LogFactoryImpl.java:336)
	at org.apache.commons.logging.impl.LogFactoryImpl.getInstance(LogFactoryImpl.java:310)
	at org.apache.commons.logging.LogFactory.getLog(LogFactory.java:685)
	at org.apache.commons.beanutils.ConvertUtilsBean.<init>(ConvertUtilsBean.java:157)
	at org.apache.commons.beanutils.BeanUtilsBean.<init>(BeanUtilsBean.java:117)
	at org.apache.commons.beanutils.BeanUtilsBean$1.initialValue(BeanUtilsBean.java:68)
	at org.apache.commons.beanutils.ContextClassLoaderLocal.get(ContextClassLoaderLocal.java:153)
	at org.apache.commons.beanutils.BeanUtilsBean.getInstance(BeanUtilsBean.java:80)
	at org.apache.commons.beanutils.ConvertUtilsBean.getInstance(ConvertUtilsBean.java:142)
	at org.apache.commons.beanutils.ConvertUtils.register(ConvertUtils.java:356)
	at org.eclipse.smila.management.jmx.client.helpers.ConversionHelper.<clinit>(ConversionHelper.java:21)
	... 14 more
Nested Exception:
Nested Exception:
[Updated on: Fri, 18 March 2011 17:23] by Moderator
Re: New SMILA trout [message #660488 is a reply to message #660478] Fri, 18 March 2011 11:31 Go to previous messageGo to next message
Hi Martin,
I've just tested trunk revision 1014 (the last - at the moment of
writing this posting - is 1016) from
http://build.eclipse.org/rt/smila/nightly/ and everything worked as a charm.
Could you be more specific about how you've build trunk and started SMILA?
Cheers
Igor
Am 18.03.2011 16:11, schrieb Martin Röbert:
> Hi there,
> Cheers,
> Martin
Re: New SMILA tryout [message #660529 is a reply to message #660478] Fri, 18 March 2011 17:34 Go to previous messageGo to next message
Hi Igor,
first of all, I used rev 1016 from trunk for testing.
I've done all standard steps as we do when creating a new SMILA-workspace (and as described on the SMILA website - dont know the exact name right now):
  • check out from eclipse SVN
  • add a new Target Platform with path to the SMILA bundles and to eclipse itself
  • launched the SMILA.launch file, stopped it immediately and edited all conflicts in the launch configuration pane
Hope this helps for clearance Smile
Martin
Re: New SMILA tryout [message #660692 is a reply to message #660529] Mon, 21 March 2011 04:29 Go to previous messageGo to next message
Originally posted by: juergen.schumacher.attensity.com
Hi Martin,
Am 18.03.2011, 22:34 Uhr, schrieb Martin R=C3=B6bert <martin.roebert@gmx=
..de>:
> Hi Igor, first of all, I used rev 1016 from trunk for testing.
> I've done all standard steps as we do when creating a new =
> SMILA-workspace (and as described on the SMILA website - dont know the=
> add a new Target Platform with path to the SMILA bundles and to eclip=
se =
> itself
> launched the SMILA.launch file, stopped it immediately and edited all=
> Hope this helps for clearance :)
> Martin
Not really, this should work (:
The javax.servlet packages should be part of the Eclipse and it has been=
at least since Eclipse 3.5.
One idea: I often have problems, when I use the IDE-Eclipse itself as th=
e
base for the target platform, because depending on the edition and the =
plugins
installed additionally it contains often bundles that produe conflicts. =
So =
I
always use a plain Eclipse SDK installation like the one used for the =
SMILA build
(see =
http://wiki.eclipse.org/SMILA/Development_Guidelines/Howto_b uild_a_SMILA=
-Distribution#Build_Requirements)
as the base for the target platform. I don't use this Eclipse for anythi=
ng =
else,
never start it, do not put additional stuff in (apart from the Delta Pac=
k).
From my experience this works better. Can you try this?
One other thing: If the JUnit tests don't run inside Eclipse, you often =
have to deactivate
org.junit (version 4....) bundles in the target platform.
J=C3=BCrgen.
Re: New SMILA tryout [message #660699 is a reply to message #660529] Mon, 21 March 2011 04:50 Go to previous messageGo to next message
Hi Martin,
you could check if javax.servlet is activated when you look at the
contents of your target platform (chose "Edit" on your Target Platform,
go to the "Content" tab and search for "javax.servlet".)
Which eclipse and which java version do you use?
BTW, which wiki site did you look at? We recently did some major
changes. Maybe it's not totally up to date...
Andreas
Am 18.03.2011 22:34, schrieb Martin Röbert:
> Hi Igor,
> itself
> Martin
Re: New SMILA tryout [message #660793 is a reply to message #660478] Mon, 21 March 2011 11:58 Go to previous messageGo to next message
I think this could be the problem Wink I cannot find javax.servlet - it is not in SMILA.extension nor in my Eclipse folder.
I use Eclipse 3.6.0 I20100608-0911 but the Yoxos-distribution.
Martin
Re: New SMILA tryout [message #660873 is a reply to message #660793] Tue, 22 March 2011 03:51 Go to previous messageGo to next message
ok, try to download an eclipse classic version and use that for your
target platform definition. It's anyway the best approach, to use an
"empty" eclipse only for target platform - just as Jürgen explained in
his posting before.
Andreas
Am 21.03.2011 16:58, schrieb Martin Röbert:
> I think this could be the problem ;) I cannot find javax.servlet - it is
> Cheers,
> Martin
Re: New SMILA tryout [message #660875 is a reply to message #660478] Tue, 22 March 2011 04:30 Go to previous messageGo to next message
I'll try this.
But is it possible to ship javax.servlet in SMILA.application as done with other javax stuff? Or in other words: why are some javax-packages included in SMILA and the servlet-API isn't?
And as I checked another workspace: I guess the servlet-api was once bundled with SMILA (checked rev. 659)?
Martin
[Updated on: Tue, 22 March 2011 04:33] by Moderator
Re: New SMILA tryout [message #660901 is a reply to message #660875] Tue, 22 March 2011 05:46 Go to previous messageGo to next message
Am 22.03.2011, 09:30 Uhr, schrieb Martin R=C3=B6bert <martin.roebert@gmx=
..de>:
> I'll try this.
> But is it possible to ship javax.servlet in SMILA.application as done =
> with other javax stuff? Or in other words: why are some javax-packages=
> Cheers,
> Martin
It's not shipped because it's supposed to be part of the recommended =
Eclipse
target platform. We also don't ship Equinox or the Declarative Services =
runtime,
for example. We might run into version conflicts, if bundles from the =
target
platform are duplicated in SMILA.
I think I'll change the documentation later to not use the IDE itself as=
the
base for the target platform. It works better anyway.
J=C3=BCrgen.
Re: New SMILA tryout [message #661166 is a reply to message #660901] Wed, 23 March 2011 07:59 Go to previous message
hi martin,
to elaborate on the given replies:
- the eclipse 3.5 SDK + delta is the normative target platform for smila
as written on our wiki.
- other eclipse versions might work, but this is not granted/supported
- in the meantime we also provide a .target @
/SMILA.releng/devenv/SMILA.target. Open that and set it as your target
platform (but click that link on the page only *after* it finished the
background task of "resolving the target platform", i.e. downloading the
bundles from eclips's p2 repo ).
note:
when we build smila based on that target platform, then only those
bundles that are actually needed for smila to run on its own are copied
into smila's bundles folder by the PDE build.
hence,
a) we only add those bundles to the smila.extensions that are not part
of the eclipse sdk 3.5.
b) the built smila doesnt contain bundles not used, such as all the jdt
stuff contained in eclipse 3.5. it even doesn't contain those bundles
that are needed to run the test during the build.
theoretically we could have assembled a target platform from scratch.
that would have been quite a bit of work, which we didnt want to spent
our weekends on ;)
On 22.03.2011 10:46, Jürgen Schumacher wrote:
> Am 22.03.2011, 09:30 Uhr, schrieb Martin Röbert <martin.roebert@gmx.de>:
>> Hi,
>> I'll try this.
>> Cheers,
>> Martin
> Eclipse
> runtime,
> target
> the
> Cheers,
> Jürgen.
thomas menzel aka tom
Previous Topic:What do the DeltaIndexing?
Next Topic:Wrong usage of read-write lock?
Current Time: Wed Jul 23 02:00:04 EDT 2025
Powered by FUDForum. Page generated in 0.10892 seconds
