Home » Modeling » Graphiti » Dashed Connections
Dashed Connections [message #660471] Fri, 18 March 2011 10:53 Go to next message
I would like to create dashed connection:
I can create my dashed connection with the code below and it works fine:
IGaService gaService = Graphiti.getGaService();
Polyline polyline = gaService.createPolyline(connection);
polyline.setLineWidth(2);
polyline.setForeground(manageColor(IColorConstant.BLACK));
polyline.setLineStyle(LineStyle.DASH);
But, if I create a style and then set the style on the polyline as shown
below, it doesn't work:
dashedStyle = gaService.createStyle(diagram, styleId);
dashedStyle.setLineStyle(LineStyle.DASH);
dashedStyle.setLineWidth(2);
dashedStyle.setForeground(gaService.manageColor(diagram,ICol orConstant.BLACK));
polyline.setStyle(dashedStyle);
Do I miss something ??
Thank you in advance,
Ali
Re: Dashed Connections [message #660703 is a reply to message #660471] Mon, 21 March 2011 05:45 Go to previous messageGo to next message
This appears to be a bug. In order for the Graphiti framework to use the
line style set at the style object, the value at the GA needs to be
LineStyle.UNSPECIFIED. Since this is not set as default for the attribute at
AbstractStyle, the framework uses SOLID (0, standard default value). As a
workaround you may set the value at the Polyline explicitly to UNSPECIFIED.
Could you please open a bugzilla to track this? Thanks!
Michael
"Ali" wrote in message news:ilvr3m$q9g$1@news.eclipse.org...
Ali
Re: Dashed Connections [message #661053 is a reply to message #660703] Tue, 22 March 2011 18:43 Go to previous message
> attribute at AbstractStyle, the framework uses SOLID (0, standard
> default value). As a workaround you may set the value at the Polyline
> Michael
Hi again,
I Opened a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=340712
Ali
> Ali
Previous Topic:how to proceed with Graphiti
Next Topic:how to create a circle in Graphiti
Current Time: Thu Jul 24 16:39:26 EDT 2025
Powered by FUDForum. Page generated in 0.08617 seconds
