Home » Archived » M2M (model-to-model transformation) » [QVTo] Debugging in a second eclipse instance
[QVTo] Debugging in a second eclipse instance [message #659204] Fri, 11 March 2011 09:28 Go to next message
I'm using the blackboxing method for adding a java library to a QVTo transformation. When I run the new instance of Eclipse to get access to the library, it seems to have access to it but when I try to debug a QVTo transformation to test it, I get an error saying that the QVTo file is not present, more specifically:
Diagnostic ERROR source=org.eclipse.m2m.qvt.oml code=0 Transformation runner initiliaze data=[] [Diagnostic ERROR source=org.eclipse.m2m.qvt.oml.execution code=200 Could not find unit 'platform:/resource/is.hi.cs.umlrefactoring.core.transformations/transforms/ClassDiagram/RenameClass.qvto' data=[]]
I've checked and double checked that the file is indeed there in both instances.
Additionally, I'm not even sure this is a QVTo specific problem but I'm going to ask anyway if anyone knows what might be wrong. Thanks in advance.
Re: [QVTo] Debugging in a second eclipse instance [message #660430 is a reply to message #659204] Fri, 18 March 2011 08:10 Go to previous messageGo to next message
I found out what the problem was, it was just my mistake. E selected the QVTo launcher instead of the interpreter for the debug configuration, and that gave me this strange error.
Re: [QVTo] Debugging in a second eclipse instance [message #700463 is a reply to message #660430] Sat, 23 July 2011 09:49 Go to previous message
hey i got the same error too. but i do chose the debug configuration-->Qvto application launch delegate--> interpreter.. so do you know where my problem is?
Previous Topic:Helper returns a sequence or set
Next Topic:trouble with this bug
Current Time: Sun Jul 27 16:13:45 EDT 2025
Powered by FUDForum. Page generated in 0.04668 seconds
