Home » Eclipse Projects » Eclipse Platform » Mouse listener on tab item of a workbench part
Mouse listener on tab item of a workbench part [message #660247] Thu, 17 March 2011 10:38 Go to next message
Hi All.
How do I add a mouse listener to the tab item of a workbench part? I need to be notified about any mouse click on the tab not just when the workbench part is activated.
As far as I can see the tab item is created deep inside the StackPrensentation so how do I get hold of it so that I can attach a mouse listener to it?
Thanks in advance,
Anders
Re: Mouse listener on tab item of a workbench part [message #660360 is a reply to message #660247] Fri, 18 March 2011 02:18 Go to previous messageGo to next message
On 17/03/11 8:08 PM, Anders wrote:
> Hi All.
I don't think its accessible via API. What is your usecase?
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Re: Mouse listener on tab item of a workbench part [message #660381 is a reply to message #660360] Fri, 18 March 2011 04:48 Go to previous messageGo to next message
Hi Prakash.
The use case is that when I click on the tab of the editor then I need to put focus to a specific component.
Anders
Re: Mouse listener on tab item of a workbench part [message #660417 is a reply to message #660381] Fri, 18 March 2011 07:07 Go to previous messageGo to next message
On 18/03/11 2:18 PM, Anders wrote:
> Hi Prakash.
Can't you override editorPart.setFocus() to do that?
- Prakash
Re: Mouse listener on tab item of a workbench part [message #660483 is a reply to message #660417] Fri, 18 March 2011 11:34 Go to previous messageGo to next message
Unfortunately no, because WorkbenchPart#setFocus is only called when the editor becomes the active editor. Not when it already is the active editor.
Re: Mouse listener on tab item of a workbench part [message #660516 is a reply to message #660247] Fri, 18 March 2011 15:59 Go to previous messageGo to next message
On 03/17/2011 10:38 AM, Anders wrote:
> Hi All.
As Prakash mentioned, there's just now way to interact with the tab in
the editor or view stack, unless you create them yourself.
When your part is activated, setFocus() will be called. Except for
when the editor is already the active part, you'll get the call.
Re-clicking on the active part to change focus is not a common pattern
within an editor/view.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Mouse listener on tab item of a workbench part [message #667328 is a reply to message #660516] Thu, 28 April 2011 03:40 Go to previous messageGo to next message
Hi Paul.
But what about the scenario where focus goes to another part of the workbench and then the tab of the editor is clicked? For instance, in the Eclipse IDE I click in the "Package Explorer" view. The focus frame is moved to this view. Then I click on the tab of the active editor and the focus frame is now moved to the editor. How is this implemented.
Thanks in advance,
Anders
Re: Mouse listener on tab item of a workbench part [message #667382 is a reply to message #667328] Thu, 28 April 2011 08:42 Go to previous message
That's what IWorkbenchPart#setFocus() is for. If a user clicks in a
view, the user has picked the focus widget.
If the user clicks on a tab or uses F6 to activate a view, the workbench
calls setFocus() on the view part to give it a chance to set focus on
one of its widgets.
PW
Paul Webster
Previous Topic:Deploy eclipse plugin
Next Topic:Problem with updating the plugin created by me
Current Time: Sun Jul 27 02:19:05 EDT 2025
Powered by FUDForum. Page generated in 0.05482 seconds
