Home » Modeling » EMF » Proxy resolval for EAttribute
Proxy resolval for EAttribute [message #660246] Thu, 17 March 2011 10:35 Go to next message
I try to utilize an EAttribute in terms of a remote reference, since
using an EReference is not suitable in my special case for several reasons.
However, I have troubles resolving the Proxy.
Are EAttribute-Proxies generally intended to be resolved automatically
analog to EReferences?
Regards, Daniel
Re: Proxy resolval for EAttribute [message #660256 is a reply to message #660246] Thu, 17 March 2011 11:02 Go to previous messageGo to next message
Originally posted by: richkulp.us.NOSPAM.ibm.com
EAttributes are just straight java class instances, such as String,
Integer, or some other class. These can't be "foreign" because foreign
refers to EMF EObjects in another EObject/Resource. Only EObjects have
the ability to be foreign and referenced.
Rich Kulp
Re: Proxy resolval for EAttribute [message #660257 is a reply to message #660246] Thu, 17 March 2011 11:03 Go to previous messageGo to next message
Daniel,
Comments below.
Daniel Strueber wrote:
> reasons.
Those reasons are?
No, absolutely not.
> Regards, Daniel
Re: Proxy resolval for EAttribute [message #660300 is a reply to message #660257] Thu, 17 March 2011 13:48 Go to previous messageGo to next message
>> reasons.
>Those reasons are?
Most basically, I have a set of model instances that are
interconnected by remote EReferences, and I want to pass
them on to an external infrastructure that performs a
certain "for all" check on all EReferences, but is designed
to deal with local EReferences only. So my idea was to use
EAttributes to distinguish the remote from the local
references. I'm having different ideas for workarounds,
but none of them is really neat, so I thought of giving this
a try.
So thanks to both of you!
Re: Proxy resolval for EAttribute [message #660317 is a reply to message #660300] Thu, 17 March 2011 16:10 Go to previous messageGo to next message
Daniel,
Comments below.
>>> reasons.
>> Those reasons are?
> a try.
Nothing you said convinces me that you can't just use the existing proxy
mechanism. There are many interesting ways to specialize how proxies
are resolve and it's not so difficult to process a model instance
without resolving any proxies.
Maybe if you explain in a little more detail I could suggest some ideas
you might try.
Re: Proxy resolval for EAttribute [message #660432 is a reply to message #660317] Fri, 18 March 2011 08:04 Go to previous message
Hi Ed,
Daniel and me intended to kind of eliminate remote references from a
transformation engine's perspective in order to perform transformations
on local models only while being embedded in a larger context.
However, we have found a proper way of dealing with this without the
need of introducing additional abnormal behavior to EMF models, as this
is rather a concern of the transformation engine than of EMF.
Thanks for your help anyway.
Stefan
Am 17.03.2011 21:10, schrieb Ed Merks:
> Daniel,
> Comments below.
>>>> reasons.
>>> Those reasons are?
>> a try.
> you might try.
Previous Topic:De-serialization of extended eCore models
Next Topic:Is it safe to call copyReferences() more than once on the same instance of EcoreUtil.Copier?
Current Time: Sat Jul 26 03:13:28 EDT 2025
Powered by FUDForum. Page generated in 0.69273 seconds
