Home » Eclipse Projects » GEF » Import a SVG image in Draw2d/GEF
Import a SVG image in Draw2d/GEF [message #659971] Wed, 16 March 2011 08:51 Go to next message
Hi!
I need import a SVG Image on Draw2d to display it and resize it.
I used "ImageFigure" class but SVG format is not supported.
Any suggestion?
Thanks!!
P.D: I use GEF, not GMF.
[Updated on: Wed, 16 March 2011 09:13] by Moderator
Re: Display a SVG image on Draw2d [message #659985 is a reply to message #659971] Wed, 16 March 2011 09:45 Go to previous messageGo to next message
In the GMF experimental SDK, there is an org.eclipse.gmf.runtime.lite SVG that contains a SVGFigure you can use with draw2d.
HTH
Mickael Istria -- BonitaSoft S.A.
http://www.bonitasoft.com/products/BPM_download.php
Re: Display a SVG image on Draw2d [message #660012 is a reply to message #659985] Wed, 16 March 2011 10:41 Go to previous messageGo to next message
SVGFigure figure = new SVGFigure();
java.lang.NoClassDefFoundError: org/eclipse/gmf/runtime/lite/svg/SVGFigure
I added it to "Referenced Libraries", what´s the problem?
[Updated on: Wed, 16 March 2011 10:41] by Moderator
Re: Display a SVG image on Draw2d [message #660041 is a reply to message #660012] Wed, 16 March 2011 11:22 Go to previous messageGo to next message
It probably means that you are missing some dependencies for the SVG Figure bundle. If you installed it with p2, it should be fine; otherwise you'll also need to add org.apache.batik and its deps. You can get them from Orbit repository.
> I added to "Referenced Libraries", what´s the problem?
Re: Display a SVG image on Draw2d [message #660047 is a reply to message #660041] Wed, 16 March 2011 12:32 Go to previous messageGo to next message
I downloaded the zip file from GMF website.
I extracted all files on Eclipse folders (plugin and features folder)... but not works.
Re: Display a SVG image on Draw2d [message #660230 is a reply to message #660047] Thu, 17 March 2011 09:30 Go to previous messageGo to next message
Any ideas for my problem?
Re: Display a SVG image on Draw2d [message #660237 is a reply to message #660230] Thu, 17 March 2011 10:04 Go to previous messageGo to next message
Use p2 to install plugins, and OSGi console to resolve dependency issues.
Re: Display a SVG image on Draw2d [message #660292 is a reply to message #660237] Thu, 17 March 2011 13:11 Go to previous messageGo to next message
Thank you very much, I will install plugins with p2 and I hope that it works!
Re: Display a SVG image on Draw2d [message #660301 is a reply to message #660292] Thu, 17 March 2011 13:56 Go to previous message
I installed GMF experimental SDK with p2 and it works!!!
Thank very much, Mickael Istria.
Previous Topic:How to create a figure with separate label?
Next Topic:How to create a diagram connection using properties view ?
Current Time: Fri Jul 25 20:34:05 EDT 2025
Powered by FUDForum. Page generated in 0.04577 seconds
